Best Way/Thoughts about lowering My G37XS
Yep^^ If you want a different drop you'll have to go coilovers, not too many options in coilovers for the X (I think only 3 or 4 sources) and they'll start about $850 up to $1600. If you go lower than swift springs you'll need full camber kit and rear toe kit for another $500 +/-. If you're good w/ wrenches I'd do the install yourself, it'll save at least $400 for the complete install (arms, toe, and springs or coilovers). Keep in mind you'll also have to get an alignment for another $100 give or take.
I haven't gotten the alignment yet I was suppose to get a new set of wheel right after spring installation but wheels were out of stock, so I have to wait. Wheels will be installed this month. I might need camber kits with bigger wheels.
I called the Swift Spring phone number and i am trying to figure out what exactly i will need besides the swift springs? if i do purchase these swift springs do i need the chamber kit or anything else? i am definitely leaning towards the swift springs now. what do i need?
And before you get it aligned just drive it easy as it may drive a bit unpredictable.
looks soo sexy in snow..
here a link with my coils set up
https://www.myg37.com/forums/d-i-y-i...l-on-an-x.html
and heres a link to my springs
https://www.myg37.com/forums/g37-sed...37-thread.html
I like my Coils
Thanks, yes I realize that is the case. They wear out even with stock springs eventually. My question is more about seeing if the Swift's have a spring rate that is matched to the stock struts. Typically aftermarket springs used with stock struts will result in an underdamped suspension.
#30
And I already have Swift's spring rate. May just have to roll the dice and try them out. Worst case is I have to get coil-overs or replace the struts with something better.
