Coilovers Installation (Need help) (Pics)
Old Dec 27, 2012 | 12:26 PM
G37Kev's Avatar
G37Kev
BOLT WONT COME OFF.. WHY..
WD40, Extender, etc.
Old Dec 27, 2012 | 12:46 PM
BluestickG's Avatar
BluestickG
liquid wrench
Old Dec 27, 2012 | 12:53 PM
rAiN's Avatar
rAiN
breaker bar or power tool.
Old Dec 27, 2012 | 12:55 PM
G37Kev's Avatar
G37Kev
I tried breaker bar and power tool. When I use the breaker bar from jack stand it broke my tool. Power tool stripped the bolt slowly.
My car only have 37k miles and bolt is harder as a mother f
Old Dec 27, 2012 | 01:09 PM
Normally I would advise this: Heat it with a heat gun. Spray it liberally with PB Blaster or Kroil. Let it soak overnight. Respray it liberally. Use an impact gun.
However you have screwed it up by rounding it off. Take the same steps, but instead of using an impact gun, you'll now have to use a damaged bolt extractor. They will cut into the bolt head to grip as you apply pressure. It is ruined, and you'll have to replace that bolt. Use a breaker bar at least 1/2" drive and at least 2' long. Like this one:
1/2" Drive 25" Breaker Bar
Damaged bolt removers:
Judging from the amount of rust visible, I'm guessing you live in a harsher northern climate. My 96 Maxima doesn't have that much rust on it. That's part of the issue making it harder for you. Good luck.
Old Dec 27, 2012 | 01:20 PM
quakerroatmeal's Avatar
quakerroatmeal
Make sure you put a wrench on the opposite end as well.. I used the breaker bar that Black Betty posted above + I used a pipe for more of an extension (I took the pipe from my low profile jack and slide it over the breaker bar, the one from harbor freight blue jack pipe fits over perfect).. As soon as I hard that loud pop..it broke loose.
Old Dec 27, 2012 | 01:33 PM
BosMaSwaG37's Avatar
BosMaSwaG37
Ah yes, I remember that c@nt of a bolt. The thing damn near bent my breaker bar. It was a bitch even on my car with 4k miles. That bolt and I actually meet again this weekend when I install my new coils...lucky for me I have an impact gun this time.
Old Dec 27, 2012 | 01:43 PM
G37Kev's Avatar
G37Kev
I actually live in Houston lol. Might as well take it to sals
Old Dec 27, 2012 | 02:23 PM
G37Kev's Avatar
G37Kev
The bolt is minor damage it still have grip left. The bolt just wouldn't come off
Old Dec 27, 2012 | 02:47 PM
I must be the only person ever to work on a G37 suspension who hasn't had trouble with this particular bolt. I have done 15 or 20 spring/coilover installs on these cars and never rounded one off or even had to use more than moderate effort. Even when I used hand tools rather than an impact gun. Lucky me.
Yes Sal can get that off for you. If you live anywhere near Baytown, I will do it for you. BTW, where did your car come from? That car has not been in Houston for all of it's 37K miles. That's a lot of rust.
Old Dec 27, 2012 | 02:59 PM
oro's Avatar
oro
I'd also look into a quality breaker bar, its like my craftsman 1/2 extension that sheered off against the demon bolt, where my Snap On 3/8 broke that bad boy loose without breaking a sweat.
Old Dec 27, 2012 | 04:26 PM
Can'tGme's Avatar
Can'tGme
If all the above posts don't work; then HEAT that b!tch! Take a torch to it and get it red hot (literally). Hit it with an impact gun. It'll come off then. You may ruin the bolt and have to get a new one but at least it'll be off.
Old Dec 27, 2012 | 04:27 PM
huwee06's Avatar
huwee06
TRUSTY PB BLASTER!
I worked on a few G37 here in Houston and never had a problem with that nut when I use PB blaster and my 1/2 breaker bar. That is a lot of rust for Houston environment ha GL
Old Dec 27, 2012 | 04:39 PM
Diego@Vossen's Avatar
Diego@Vossen
Bolt grip!
Old Dec 27, 2012 | 05:26 PM
G37Kev's Avatar
G37Kev
I bought the car from Ultimate Automobiles in Stafford. Car came from Austin.
Looks like the heat did work.
I literally had to take a blow dryer and stood there for 20 min since i didnt had a torch.
10am-4:30pm only got one front coilovers done while all are still sitting on stock lol.
To be continue.... tmr
