Brake rust
Old Sep 25, 2012 | 10:06 AM
stvsfx's Avatar
stvsfx
Brake rust
Hey guys. So I've got rust on all 4 brake rotor hubs (not where the pad meets the rotor). 1) Has anyone else had this happen? 2) Any good techniques you guys use to remove the rust and prevent it from happening again. I've had many cars of the years and this is first with this issue.
Thanks
- Steven
Old Oct 13, 2012 | 02:39 AM
Track Bandit's Avatar
Track Bandit
Brake Rust
If the rotors are OEM or even after market, sometimes they are not coated on the hat part with either a paint, EDP coating or plated. If they are bare steel, then you can wire brush them using a round wire wheel which you can get at Lowe's or Home Depot and remove all the rust. You can then paint them using any good high quality enamel paint or if you don't mind them being flat black in color, then wood stove high heat paint. Pain in the *** but in the long run it will look better. Good luck.
Al
Prometheus
General Tech Questions
Nov 9, 2015 01:23 PM
Mattimus
Oct 4, 2015 01:33 PM
Bennyjoel
Sep 30, 2015 11:56 PM
Irishcurtis
Sep 30, 2015 11:39 AM
VIVID
Sep 27, 2015 09:45 AM
