PADS and ROTOR recommendations?
Old Aug 31, 2012 | 06:03 PM
randy0211's Avatar
randy0211
Looking for nice set up with less brakedust.
Is there any good slotted/drilled rotors out there?
Old Sep 1, 2012 | 02:29 AM
quakerroatmeal's Avatar
quakerroatmeal
Centric Rotors and Brake Pads are popular with good prices. You'd want ceramic brake pads if you want less brake dust. You'll sacrifice initial bite most the time with ceramic pads that dust less.
Old Sep 1, 2012 | 04:38 AM
unknowndesi's Avatar
unknowndesi
Give these a shot, I heard these work great
Stoptech make some pretty affordable slotted rotors for our cars
If you want OEM stopping power stick to Akebono pads(same ones that Infiniti carries with out the Nissan branding)
If you want more stopping power than stock, stick to Hawk HPS or some Project Mu's
For the better clamping force I've heard great things about Hawk DTC's
more stopping power = more brake dust
Old Sep 1, 2012 | 01:52 PM
blackvr4tt's Avatar
blackvr4tt
Cross Drilled or Slotted Rotors - what do ppl prefer?
I hear cross drilled vents heat a little better but is harder on the brake pads. I think I'm leaning towards slotted if that's the case.
Old Sep 1, 2012 | 07:14 PM
Track Bandit's Avatar
Track Bandit
Slotted rotors have less of a problem with heat cracking if you ever track the car. They also don't reduce the overall rotor contact surface with the pads for a better bite and scouring of the pad surface. They are not necessarily tougher on brake pads. People keep thinking that they act like knife blades scrapping a thin layer off the pad surface at each pass. What's really causing most of the pad wear is the amount of heat generated during the braking process. The greater the heat generated by hard braking, the more the pad wears down. Remember that pad deposition on the rotor face during bedding in is very important for good stopping power. This transfer of the pad material from the surface of the pad to the embedded pad material in the rotor is one of the reasons for the wear going on. It's sort of like a track which when clean (known as a green track) isn't very grippy against the tires. Once they start laying down some rubber, the track gets more grippy and now the tires start wearing out very quickly because of this exchange with the excess going off to the outside of the turn. Similar things happen with the pad/bedded in rotor face during hard braking. At least that's what I've been taught.
Al
Old Sep 4, 2012 | 01:27 PM
jon23's Avatar
jon23
Guaranteed no dust, and second to none performance in tough rain! Breaking power MIGHT suffer slightly though...
Old Sep 4, 2012 | 01:46 PM
DGGal's Avatar
DGGal
Minnesota G owners
^^LOL, too funny!
Old Sep 4, 2012 | 07:18 PM
Fezzik's Avatar
Fezzik
My vote is for the racing brake 2 peice rear and front rotors and pads. They did awesome at the Tail of the Dragon
Old Sep 7, 2012 | 11:52 AM
randy0211's Avatar
randy0211
Originally Posted by jon23
Guaranteed no dust, and second to none performance in tough rain! Breaking power might suffer slightly though...:d
hahahahahaha
Old Sep 7, 2012 | 11:53 AM
randy0211's Avatar
randy0211
Where can I pick up Centrics, I heard they are the same maker as Stoptech
Old Sep 7, 2012 | 11:59 AM
randy0211's Avatar
randy0211
LMFAO....
What are some of the price rage for the rotors?
I want something with a crazy bite (stop n go in nyc with a 6spd is crazy fun)so I might go with hawks DTC ...recommend any vendors?
Old Sep 7, 2012 | 12:29 PM
randy0211's Avatar
randy0211
Al
Makes sense
Old Sep 7, 2012 | 03:17 PM
ashmostro's Avatar
ashmostro
Just get OEM rotors and very good pads for the best street performance.
You don't need pricey two piece rotors unless:
a) you want the bling, or
b) you race and will actually notice the reduced inertia and need the additional cooling capacity.
As for "good pads" look into Carbotech bobcats, racingbrake ET500's, or the others that have been mentioned already. I'm currently running ET500's but will be switching to Carbotech so that I can swap in race pads without having to scour my rotors each time.
Stevolkz33
May 28, 2016 02:36 AM
rk325
Oct 13, 2015 01:51 PM
EnYcee-G
Oct 4, 2015 09:27 PM
Jsmitty2002
Sep 29, 2015 07:55 PM
xmajd92
South
Sep 28, 2015 07:22 PM
