H&r and eibachs fender to ground measurements?
Old Jul 16, 2012 | 12:02 AM
blackgp2006's Avatar
blackgp2006
I was wondering if you guys would be kind enough to help me out. i would like some H&R and eibachs fender to ground measurements..
The Eibachs should lower the front,but the rear seems to be lower.
On so many pictures ive seen here it doesnt seem that way.
I saw gansta999 and hes on H&R's.His car looks lower than the eibachs setup . He looks like hes on coilovers. May its he is using shorter tires??
i hope you guys can help me out.
Thanks
Old Jul 16, 2012 | 12:10 AM
Track Star's Avatar
Track Star
Sorry i dont have h&r's to measure for you but heres some helpful info. Depsite the advertised drop heights, the Eibachs and the H&R's usually always run lower especially when they settle in. This is true for many other makes of cars. The Eibachs always and H&R's always run lower than they advertise. As for the drop distance between the two, the H&R's go close to 1/2" lower all around than the Eibachs do. So hopefully that will answer your question. If you want to go as low as you possibly can with springs, go H&R. If you want a decent but conservative drop, go Eibach. Hope this helps!
Old Jul 16, 2012 | 12:15 AM
dimsler's Avatar
dimsler
Just installed H&R sport springs on a friends car.
H&R sport springs, 1.3 f 1.2r 245/40/19 / 275/35/19 center to fender 14" all around, I guess x2 straight to the ground.
Best drop on springs I've seen for a Sedan, because it adds that nice rake, I actually run my coilovers at the identical height, 14" all around.
Old Jul 16, 2012 | 01:38 AM
Sunny G's Avatar
Sunny G
My car actually gets lower with the stocks on than with the 20"s. My car is having some work done to it and it will be back tomorrow or Tuesday and I'll do the measurement for you. As for the drop being lower than eibachs it is. If you go by advertised drop for the H&R always add .35 drop front and rear.
Old Jul 16, 2012 | 04:30 AM
BobbieShen's Avatar
BobbieShen
Old Jul 16, 2012 | 09:02 AM
rpm&my_G35's Avatar
rpm&my_G35
Here's mine on Eibach PK
https://www.myg37.com/forums/3440497-post44.html
There are other sedan in this thread too. More near the end
https://www.myg37.com/forums/brakes-...atabase-3.html
Old Jul 16, 2012 | 01:42 PM
blackgp2006
wow,how is the ride with the stock shocks before you added the Tokico shocks?
i had h&r springs on vw cc and it dropped the car just as descirbed..
it rode perfect..
thanks for everyones reply
Old Jul 16, 2012 | 01:44 PM
Here's another thread on G35 that's helpful. I'm on B&G S2 springs and they're very similar to H&Rs a pretty aggressive drop, 25 5/8" front and 26 1/8" rear to the fenders on 245/35/20s
Data Base: Lowered with Aftermarket Rims/Tires - G35Driver
Old Jul 16, 2012 | 04:31 PM
Sunny G's Avatar
Sunny G
TI had the springs installed straight with the shocks so I don't know how it would have rode with just the springs. From what I've heard is that the stock shocks will go out much quicker. I still haven't gotten my car back from my mechanic when I do I'll measure it anyway for you. The ride now is a little harsh but I can guarantee that it's the tires on my rims. They are bald and super noisy and once they get replaced I'll have a better idea. Handling wise it's much better than the eibach springs but a little under dampened.
optikol
Jan 28, 2016 07:31 PM
Rybitron
Nov 18, 2015 03:11 PM
Kojack
Oct 9, 2015 05:53 PM
RexHavoc
Oct 2, 2015 11:47 AM
VIVID
Sep 29, 2015 10:58 AM
