Something new from KW: KW DDC ECU Coilover Kit
Old Jun 2, 2012 | 12:29 PM
ModBargains.com's Avatar
ModBargains.com
I'm not sure if you guys have heard about the new KW DDC ECU Coilover kits by KW, but it sure looks promising.
With the new Dynamic Damping Control, DDC, KW has designed a new coilover suspension, which uses the original 3-way button to adjust the damping. KW combines the individual height adjustability of the coilover suspension with the adaptive OEM damping control.
The driver can choose between 3 modes: "Comfort" for bad road conditions or just a relax ride, "Normal" for sporty daily use as the best compromise between performance and ride comfort or "Sport" for best handling and response.
Fichtenberg, May 9th, 2012 - Three modes driving pleasure and the opportunity to adjust the damper characteristics via iPhone, this is what the KW DDC ECU coilover kit makes possible. With the free KW DDC App, the dampers can individually be configured via an iPhone, iPad or an iPod touch. For the secured WiFi-connection to the suspension control unit, only an optional W-LAN module is required. The KW DCC ECU coilover kit allows a continuous lowering of up to 40 mm within the German TÜV-tested adjustment range.
Skip ahead to 1:39 for the fun stuff!
Information off KW's website:
Product news - KW automotive GmbH
More Info: KW DDC coilover kits /// with electronic damping control /// KW automotive GmbH
Currently applications are limited to VW, but I heard there will be more applications available eventually...hopefully a G37 application?
What are your thoughts on this system? Yay or nay?
-Frank
Old Jun 2, 2012 | 12:56 PM
G37Sam's Avatar
G37Sam
That is definitely the coolest thing I have seen in a while! How much more expensive than a standard V3 would this be?
Old Jun 2, 2012 | 01:35 PM
GET_SOME's Avatar
GET_SOME
isnt this kina the same thing as the tein edfc? to be quite honesr im not sure i would want to be fumbling with my phone trying to set damping and why it only works with apple products. not everyone has iphone
Old Jun 2, 2012 | 01:44 PM
G37Sam's Avatar
G37Sam
I'm sure you can have old school buttons hooked to it if you want, the iPhone app is just a plus
Old Jun 2, 2012 | 01:49 PM
Kuro's Avatar
Kuro
Just get an iphone James lol
Do you have info and price on this?
http://www.kw-suspension.com/us/kw_hls.php
Old Jun 2, 2012 | 03:16 PM
xeddyboi420x's Avatar
xeddyboi420x
omg that is sick
Old Jun 2, 2012 | 03:17 PM
ModBargains.com
I'm pretty sure the app will be eventually released for android users like me, but nonetheless I think it's a cool feature!
-Frank
Old Jan 20, 2013 | 02:41 AM
SgtGoldy's Avatar
SgtGoldy
Dead thread... buuuuttt:
any news on a G37 application?
Old Jan 20, 2013 | 09:51 AM
ECain18's Avatar
ECain18
It seems these will not work on the g37 as it does not have active damping technology. It looks like you use your ipad/iphone to set it up and then when u are actually driving, you just use the comfort/sport stock buttons in the car. This is pretty neat and def should be compatible with the newer q's since i believe it will have an active suspension
jfisher
Apr 25, 2017 01:22 PM
Raffay Khan
Intake and Exhaust
Sep 14, 2015 10:47 PM
jfisher
Sep 9, 2015 04:17 PM
