G37x Eibach PK Alignment
so i just got my alignment from 2 different shops back to back cause the first shop got me thinking wtf? ok so i went to the first shop and got my alignment and then on the print out they gave me it said my car was a 2008 g37 rwd when its a 2011 awd and on top of that the printout they gave me didnt even change my front/rear camber only the toe. so i went for a second opinion. should i bring both printouts back to the first shop and try to get my money back?
the before was how i left my first shop talk about bad.... should i get a camber kit?
Looks like the first place didn't do anything. The 2nd printout looks about right. You should be ok without a rear camber kit, but if you want to be in specs then get the kit.
This is what I was a bit afraid of, I figured with how much more significant the drop is on the X coupe's that a rear camber kit might be needed. I haven't installed my springs yet but after seeing your print out I think I'm going to go ahead and order the rear camber kit to get the rear back in spec just for peace of mind. I know the toe is more important for tire wear and that yours is in spec but I'm just too picky with this stuff
TheIvoryG
Sep 23, 2015 02:06 AM
