Megan Racing camber arms
Battle Version camber arms
Well, I finally put down on a set of coilovers. Now I'm looking for camber arms. I like the SPL arms, but I think -10 degrees of camber is way more than I'll ever need. I like battle versions and the megan racing arms mainly because they look like they are actually decently constructed. Anyone running either of these? Any one know the range of camber adjustment? The sites dont say. Either way I'm trying to stay away from SPC and Ichiba, build quality just isn't what I'm looking for.
ohhh I see. well then the SPL pieces are good stuff but are a little on the pricy side i think one of the forum vendors sells SPL stuff try contacting him. as far as other companies than the ones listed i think only wicked tuning and stillen have been left out that make adjustable rear camber arms. the one thing i will say is your suspension is what your car rides on and its what your life depends on. dont cheap out where a failure from a cheap part may cost you your life
The only thing that I didnt really like with the Megan arms is that they are steel constructed instead of aircraft grade billet aluminum. They still use a spherical bearing. I think for just spirited street driving, they would be ok. For everyday track use, definitely not.
I've never heard of wicked tunning, I'll have to check them out. Stillen is in the same boat as SPL, good stuff, but more than I think I need. Thanks for the info
Ended up going with the battle versions. These things are like $175 an arm on the battle version site, but if you head over to Battle Version Rear Camber Links-Z34/V36 370Z G37
they're $216 shipped. I'll post more pics once I get them installed.
http://www.flickr.com/photos/47892165@N06/7024147829/
Kojack
Oct 9, 2015 05:53 PM
