Swift-R Springs Installed! PICS!
Old Mar 24, 2012 | 08:44 PM
  #106
dtran2714's Avatar
dtran2714
Here is my Swift and KONI sport yellows installed
Old Mar 24, 2012 | 10:23 PM
  #107
dagon68's Avatar
dagon68
I suck at photography! Hey dtran do I understand correctly, you installed the swift springs on koni coilovers? Your drop looks dead on man! I'm not happy with the front drop on swift springs alone. It needs a little less gap in front...
Old Mar 25, 2012 | 02:17 AM
  #108
dtran2714's Avatar
dtran2714
I installed swift springs and koni shocks.
Old Mar 25, 2012 | 01:06 PM
  #109
TVPostSound's Avatar
TVPostSound
They (Koni) are not coilovers, and do not affect ride height.
Old Mar 25, 2012 | 03:01 PM
  #110
kkokko's Avatar
kkokko
How's the ride compare to stocks
Old Mar 25, 2012 | 03:27 PM
  #111
TVPostSound
I saw your pics, it seems that the fronts did not drop enough.
Im down to 26 1/2 with Eibachs' 1.2 drop, but Swift says theirs is 1.3???
You should be below 26 1/2".
Old Mar 27, 2012 | 11:04 AM
  #112
weaver's Avatar
weaver
anyone install these on a vert?
Old Apr 19, 2012 | 03:49 PM
  #113
dagon68's Avatar
dagon68
Very nice man! Thanks for the info. I still need an alignment but IM guessing once I do, It will just be more money (camber kits) so I have been putting it off.
Old May 4, 2012 | 10:07 AM
  #114
Brooklynstar23's Avatar
Brooklynstar23
Old May 8, 2012 | 10:51 PM
  #115
DjFromVA's Avatar
DjFromVA
Got my swift springs in 2 weeks ago, rears were an easy switch front took some time, make sure u measure ahead of time to prevent rubbing, trust me lol. Anyways love the feel. To me it feels a little stiffer than stock but very manageable. When ppl take rides in it there is no discomfort. The only reason i noticed a change was because ive been driving the car for 6 months. If you're on the fence about these i recommend you pick them up!
anyways on to the (cellphone) pics!
BTW i just put the fronts in last night
Rear Before
[IMG][/IMG]
Rear After
[IMG][/IMG]
Front Before
[IMG][/IMG]
Front After
[IMG][/IMG]
Before
[IMG][/IMG]
After
[IMG][/IMG]
As it sits now :-)
[IMG][/IMG]
Forgestar F10
| 20x8.5 + 38 w/ 15mm spacers
| 20x10.5 + 46
Hankook tires 245x35x20 and 285x30x20
This drop plus and exhaust is perfect for me!
Old May 8, 2012 | 11:51 PM
  #116
kkokko's Avatar
kkokko
Hey Dagon,
Did you trim the fender for the rears? It looks like I'm rubbing the fender and possible the bumper bracket on 295/30 tires 42 rims
Old May 9, 2012 | 09:37 AM
  #117
dagon68's Avatar
dagon68
Originally Posted by kkokko
Hey Dagon,
Yes I trimmed the fender liner and shaved the bumper bracket while wheels were off but the bracket wasn’t necessary. I did this before so not sure if it would have rubbed or not. Fender liner is easy to trim with box knife and is probably what’s rubbing on your ride. Should be an easy fix and possibly trimmed with a razor with wheels still on. GL
Old May 9, 2012 | 09:40 AM
  #118
dagon68's Avatar
dagon68
Hey DjFromVA whats your wheel/tire specs? Your ride looks nioce!
Old May 9, 2012 | 12:31 PM
  #119
DjFromVA's Avatar
DjFromVA
Forgestar F10
| 20x10.5 + 46
and thanks for the love
Old May 18, 2012 | 11:33 PM
  #120
kkokko's Avatar
kkokko
what camber setting at you at for your rears? Did you also add spacers to the rears? I'm pretty sure I'm rubbing at the bracket because I put masking tape on it and see marks on the edges... For sure I'm rubbing the liner on small bumps/turns.
My specs are almost exactly like yours, except my rears are 42 instead of 45. I'm on swift springs with non-sport suspension and no spacers..
My rear camber is at -1.75 and -1.76
Vossen CV1
20x9.5 +32 255/35 toyo proxes
20x10.5 +42 295/30 toyo proxes
Swift Sport Springs
Tanabe Axle Back
