New Springss!
New Springss!
So i bought a set of Nismo 370Z springs to hold me over until i get enough for my coils. didnt spend much on them at all. Yesterday ii finally had a chance to put on the rear springs and wow! over an inch drop from stock height!
I have to pick up a spring compressor this week and do the fronts over the weekend, so for now the car looks a little ... odd.
i dont have any FULL shots of before and after.. i totally blanked on taking those. but here is a shot of the measurements before and after
Edit: Pictures are on an EMPTY TANK (10mi till empty) so height is higher then with full tank. i didnt put that factor into place when installing and taking the pictures. New pictures going up today of the after with full tank of gas! WOOPSYY lol
Before: Just over 28"
After: just Under 27"
Entire car Before: (older pic)
Shot of rear After :
So far i can tell the back seems more planted and a little stiffer from the factory springs. But after the fronts go on ill post up on hoe the ride is
I thought most ppl install the fronts (off the 370z) and ditch the rears...
370Z springs experiment - Page 4 - G35Driver
this weekend the fronts go on so ill be able to give a real feeling on the ride difference and what not.
Edit: from that post, i can see he used the standard 370z springs, whereas i am using the 370 Nismo springs which are stiffer and shorter as the gismo Z is i believe 1/2 inch lower the the standard
i hadn't done much research about the 370Z springs on G's before i bought them. i just figured a quick and lower cost fix to my 4x4 issue until i have enough for coil overs lol
You cant use the 370Z sport rear springs on the 07+ G sedan. They are the wrong size, or so I'm told.
^ G37S, you can see it in his pics (trunk) and it has BBK
Maybe you have a full tank and he's on E
Also, check both sides, they can vary a bit.
Edit...OK Movinon, you're right. I just looked up mine (stock) and they were also 27 5/8" and the fronts about 28".
Weird
Weird
i have a full tank in now so ill remeasure it today and see what the actual measurements are with wet weight. i didnt even think of putting the factor that i was empty into the mix
will get new measurements today and post pics!
The nismo springs fit perfectly where the factory G sedan springs were..? i didnt have any issues at all with it
