Stech with spc rear camber kit question
Old Aug 11, 2011 | 07:51 PM
ben_ben125's Avatar
ben_ben125
Hi i got stech with spc camber kit in my g37s. I went to an alignment place and they told me i need adjustable toe bolts for my rear camber kit .for it ti align properly . Wuth my setup now yo those who have the same setup did u guys buy a toe bolt too ? Or just left it thr way it is.
Old Aug 11, 2011 | 08:15 PM
ben_ben125's Avatar
ben_ben125
And how is your tire wear
Old Aug 11, 2011 | 09:22 PM
Doggy's Avatar
Doggy
I'm riding on s techs with 0 camber kits! The tire wear sucks. But
If your toe is off everything is off
Old Aug 11, 2011 | 09:24 PM
ben_ben125's Avatar
ben_ben125
Thanks
Any other feedback
Old Aug 11, 2011 | 09:46 PM
P Casey's Avatar
P Casey
are you talking about the front or rear? If you have the rear spc camber kit they should be able to adjust it as close to spec as possible. The front is a different story.
Old Aug 11, 2011 | 09:55 PM
1cleanG's Avatar
1cleanG
NextLevel Performance
Correct, SPC kits come with the arm and toe bolt. This should allow you to get fully within spec without a problem.
With aligning and tire wear, Pcasey is right, THE TOE must be ON! THIS is what will absolutely tear up your tires.
You picked a great camber kit...just a wrong shop to install it. To be within spec, just make sure you're -1.8 of camber or less(as in closer to zero). Most on springs prefer like -.8 to -1.0.
I'm on KW V3's and mine is -1.8 in front and -1.2 in rear. Tire wear is perfect.
Hope this helps
Ipp391
Aug 28, 2015 09:27 AM
Jensen Mathew
Aug 16, 2015 08:06 PM
kyro840
Aug 9, 2015 01:38 PM
