Rare Hotchkis Sway bar Group Buy***
Old Jul 30, 2011 | 06:48 PM
  #151
Rickblkg's Avatar
Rickblkg
Haha thats so true I was actually thinking the same thing when I was driving around today!!!
Old Jul 31, 2011 | 11:14 AM
  #152
jb606's Avatar
jb606
For those sedan owners that DIY'ed their sway bar install, did you have to drop the exhaust like in the directions or were you able to maneuver the bar out??
Thanks!
Old Jul 31, 2011 | 12:11 PM
  #153
phreekeeG's Avatar
phreekeeG
^I'm wondering the same thing (for the coupe). Also wondering if it is possible to drop the whole muffler at the hangers instead of breaking the seals. i would rather avoid the potential to introduce any leaks and have to buy new gaskets, if possible. If no one knows, I'll find out after the bars arrive..
Old Jul 31, 2011 | 08:03 PM
  #154
inapirekim's Avatar
inapirekim
I did the install and I removed the exhaust behind the x pipe. I have an ARK exhaust and it was all up in the way. Install was easy only took about three hours. I brook off one of the bolts for the exhaust brackets and it took longer to fix that than the install did.
Old Jul 31, 2011 | 11:22 PM
  #155
Rickblkg's Avatar
Rickblkg
Guys and Gals, I had a shop do the install and now im getting a crazy vibration in the front do you think they messed up???
Old Aug 1, 2011 | 09:00 AM
  #156
mikejg's Avatar
mikejg
Take a peek under your car. You should be able to see the connection points (end links/bushings) around the spash shield and maybe see if something isn't connected correctly???
Old Aug 1, 2011 | 12:34 PM
  #157
inapirekim's Avatar
inapirekim
^^^^+1 on that and check the exhaust that could make it vibrate. Did you notice it right away or did it take a while before it started vibrating? They might have over torqued a bolt and now its broken and thats why it's vibrating.
Old Aug 1, 2011 | 01:56 PM
  #158
Rickblkg's Avatar
Rickblkg
I feel it right under my feet so im assuming its the front sway bar!
Old Aug 1, 2011 | 02:48 PM
  #159
inapirekim's Avatar
inapirekim
You could have broken a toe bolt, I don't know if that would couse it to vibrate but I would check it out before diriving anywhere.
Old Aug 1, 2011 | 03:10 PM
  #160
Rickblkg's Avatar
Rickblkg
Yeah i will look at it, I dont drive the car mon-thursday anyways... Thanks a lot guys!!!
Old Aug 3, 2011 | 10:33 AM
  #161
mikejg's Avatar
mikejg
Did you ever figure out what was causing the vibrating?? I'm curioud to know in case something happens to my car I'll know what to look for.
Mike
Old Aug 3, 2011 | 11:32 AM
  #162
Rickblkg's Avatar
Rickblkg
Mike
No not yet, I am out of town so thursday morning I will check, took the day off ..... I will keep you updated
Old Aug 3, 2011 | 12:21 PM
  #163
bingpwr's Avatar
bingpwr
End link broken maybe?
Old Aug 3, 2011 | 01:03 PM
  #164
DocJohn's Avatar
DocJohn
G-DOG
Thanks!
I had to drop the exhaust when I upgraded my rear sway bar in my '10 G37X, but I think I read that some owners didn't have too. I had my rear wheels on ramps (I didn't use jack stands) so maybe that has something to do with it?
I remember that after several attempts I managed to finally be able to maneuver the OE rear bar out with the exhausts still in place, but then I couldn’t figure out how to get the new sway rear bar in place (at least not without scratching the hell out of it or damaging something under my car). So I just dropped the rear pipes of the exhaust and mufflers and it was an easy install after that.
Old Aug 3, 2011 | 01:30 PM
  #165
ScuderiaFan's Avatar
ScuderiaFan
Just ordered mine. Here is an updated list. Thanks Rickblkg for the group buy.
Rickblkg-g35-awd ORDERED
Sdbolt-g35-rwd
Tpc303-g35-awd
Allentowng37-g37-awd- ORDERED
NoirG-g37S Coupe RWD- ORDERED
inapirekim- coupe G37s-rwd ORDERED
hoofhearted- RWD coupe G37s-rwd ORDERED
fezzik-rwd ORDERED
rvanderwerf - RWD sedan G35S 08
johnnyblast- RWD sedan G35S 07'
07g35Nick-AWD-Maybe
VQsmile-Maybe
Invalid - RWD G37s Coupe ORDERED
Neoninja- 09 RWD Sedan-ORDERED
webf2011-g35-awd
mikejg- '11 AWD sedan ORDERED
Sena
rdeol - 07 g35s sedan ORDERED
Jubbliepuff - 09 RWD vert
Okita240 - '11 RWD Sedan ORDERED
navecm - 08 g37s RWD coupe ORDERED
psychdaddy - 07 G35x AWD - ORDERED
racerxvi - 04 G35 Coupe RWD
blklegend - 07 G35X Sedan - ORDERED
Corvettekid - 11 AWD Sedan - ORDERED
phreekeeG - 08 G37 coupe RWD - ORDERED
ScuderiaFan - 10 RWD Sedan - ORDERED
