benefits of stiffer suspension
Old Jun 19, 2011 | 08:10 PM
chogrilla's Avatar
chogrilla
nooob question here i suppose...so im considering lowering the car but from what ive read so far, lowering the car will inevitably stiffen the suspension. i know stiffer suspension will make the ride quality a lil more "harsh" as you would feel more of the bumps/imperfections on the road..especially here in nyc. However, does the stiffer ride improve car handling? what benefit is there to a stiffer suspension as apposed to a softer one besides that it looks better.
Old Jun 19, 2011 | 08:30 PM
v.b's Avatar
v.b
If you have to ask a question like this, the chance of you ever reaping benefits from an aftermarket suspension is quite negligible.
Old Jun 19, 2011 | 09:36 PM
samps's Avatar
samps
I've found that stiffer suspensions make passenger bounce more.
Old Jun 20, 2011 | 12:56 AM
KAHBOOM's Avatar
KAHBOOM
Super Moderator of Pwnage
Much depends and what you do to lower the car, spring rates resulting suspension geometry etc...
Just lowering does not necessarily mean stiffer. For example some of us on Tanabe springs have only a 5% stiffer suspension. Barely even noticeable.
Old Jun 20, 2011 | 02:21 PM
Mike's Avatar
Mike
lower is just lower, not stiffer.
A spring is a spring; the spring constant (k) remains static, unless you have a progressive rate spring.
Want better handling? Get better shocks. Not that cheap k-sport/bc/megan/(insert any "coilover" under 4000 here) junk, but a set of real shocks.
Or better yet, just upgrade your tires.
Old Jun 20, 2011 | 05:01 PM
1NEETO's Avatar
1NEETO
+1 on shocks. I have combined springs with koni yellows in the past (other cars) and handling was definitely improved.
Sleepstupid
Oct 15, 2015 11:16 AM
Soccer4555
Sep 30, 2015 05:31 PM
JC-RH
Sep 27, 2015 09:36 AM
Wreckreation
Sep 21, 2015 06:27 PM
m3clubracer
Sep 20, 2015 09:20 PM
