just installed coilovers.......?
Old May 30, 2011 | 07:45 PM
blueslateg's Avatar
blueslateg
hey guys. just finishd installing my stance gr+ pro coilovers. the car sits pretty low as i didnt mess with the factory height on the coils. how long do i drive the car before i can go get it alinged? as far as i can tell the alingment didnt change at all. drives just as straight as it did before but im worried about the camber and toe. thanks!
another question....for those stance experience.....how high can you raise the car? since stance coils adjust by moving the inner tube (not the spring and perch) if you raise the car too much the inner tube will pop out of the lower bracket that it screws into. my car is sitting too low for my taste and i want to raise it up quite a bit but dont know how high it will go. if anyone can help me out id appreciate it. thanks!
Old May 30, 2011 | 07:48 PM
bingpwr's Avatar
bingpwr
A week or two should be enough for settling.
Old May 30, 2011 | 08:00 PM
hispeed-lowdrag's Avatar
hispeed-lowdrag
A week is good. you won't be able to tell a difference (the alignment would have to REALLY be out for you to tell. But just a degree or two of toe can kill your tires.
Old May 30, 2011 | 08:42 PM
buffpatel's Avatar
buffpatel
Sorry if this is an obvious question but if you install camber kit along with coilovers should you also wait the 1-2 weeks before getting alignment or am I just being paranoid and it really doesn't matter?
Old May 30, 2011 | 09:23 PM
blueslateg's Avatar
blueslateg
haha nice last name. im a patel as well
Old May 30, 2011 | 09:37 PM
Doggy's Avatar
Doggy
Yes 1-2 weeks
Old May 30, 2011 | 09:43 PM
hispeed-lowdrag
afirm. always wait a week or so to change the alignment after any work is done
Old Jun 1, 2011 | 07:37 PM
InspiredMan's Avatar
InspiredMan
pictures?
Old Jun 1, 2011 | 08:30 PM
ReddieG37's Avatar
ReddieG37
You should wait a week or two whenever you change springs/coilovers since you wanna it some time to settle before aligning.
Old Jun 1, 2011 | 08:45 PM
JJsBusaRox's Avatar
JJsBusaRox
I had mine all done the same day (lower, camber and alignment). I came back two weeks later to raise the rear a bit and did another alignment and there were no changes in the alignment..
Team_STILLEN
Future Models
13
Sep 5, 2016 03:13 PM
Thedbarz
33
Feb 9, 2016 12:05 AM
WillCo1
Sep 1, 2015 11:31 PM
Sway_NV
Intake and Exhaust
Aug 30, 2015 08:46 PM
cparise
Aug 19, 2015 01:51 PM
