M370 install
Old Aug 30, 2015 | 06:01 PM
Sway_NV's Avatar
Sway_NV
I'm too young to die!
M370 install
So next weekend I'll be installing my ported M370 manifold and I've never done a manifold before. Done a million intakes, couple exhausts, coilovers, shocks/springs, a clutch/flywheel a time or two so I believe I can do. I'm just wondering what to expect. Any tips from those who have done it? I was going to do it today but it got late and I wanted to do a little research online, but I can't find anything on the install... No diy's or write ups or anything... Also looking at the new vs old mani, I noticed the new mani doesn't have any hose connections where the old one has 2... Interesting
This is the only thing I have to help with the install:
http://motordyneusa.com/wp-content/u...ION-MANUAL.pdf
But if I take the TB's off the way this says... Don't I have to do that ECU reset TB position/air volume stuff? Turn the ignition on and off approx 50 million times, press the gas pedal down 17 times within 5 seconds, turn the car on and then off, do 3 right turns and clap your hands etc... Or whatever.
Couldn't I just leave everything attached to the TB and just undo them from the mani and lay them to the side? Or would that be a bad idea? Anywho thanks for the advice!
Old Aug 30, 2015 | 06:44 PM
jroyalty7's Avatar
jroyalty7
Use the motordyne instructions along with the fsm for the torque order and specs. Work slowly and leave everything plugged in, just disconnect battery. Once you get everything unbolted the manifold just lifts out, but make sure you do not drop anything down into the lower manifold! Cover it with a towel if need be. Reinstall in reverse order. I was pretty nervous about this at first but it's really straight forward bolt on. I even had to fabricate the tconnections since I bought mine used and motordyne forgot to send then with my tubing. Give yourself time and you'll be fine!
Old Aug 30, 2015 | 06:54 PM
jroyalty7's Avatar
jroyalty7
M370 install
Here's a few pics with manifold off and installed
Edit
I'll try again in a bit it won't upload my pics
Old Aug 30, 2015 | 08:46 PM
PongSanity's Avatar
PongSanity
M370 install
I followed those instructions and my install went flawless. Just follow those and u good. The tb reset on my tb thread in the review section.
Team_STILLEN
Future Models
13
Sep 5, 2016 03:13 PM
chuckie311
78
Apr 18, 2016 08:56 PM
Thedbarz
33
Feb 9, 2016 12:05 AM
cparise
Aug 19, 2015 01:51 PM
