View Poll Results: Which one?
TANABE SUSTEC PRO S-OC
24
54.55%
Stance GR+
20
45.45%
Voters: 44. You may not vote on this poll
TANABE SUSTEC PRO S-OC or STANCE GR+?
Old Jun 23, 2011 | 04:13 AM
JJsBusaRox's Avatar
JJsBusaRox
I love my Stance as well. Ride is way better than stock. At the time of purchase (April), price diff between the two was 250.
Old Jun 23, 2011 | 10:22 AM
Topher9425's Avatar
Topher9425
I was contemplating between these 2 companies, then pulled the trigger and went with the BC Racing Coils......heard great things about these, and my vendor gave me a price I could resist!
Old Jul 1, 2011 | 09:52 PM
jmlenz's Avatar
jmlenz
Sustec is prbably the more comfortable of the two (most similar to OEM sport) while still increasing handling prowness. Im running them and have zero complaints
Old Jul 2, 2011 | 12:36 AM
Xenolith666's Avatar
Xenolith666
I think I might go with Tanabe, since they're half the price of KW's and they seem good quality with few bad reviews. SOLD!
Old Jul 2, 2011 | 01:33 AM
Doggy's Avatar
Doggy
Just remember there is 0 dampening on the tanabes ^
Old Jul 2, 2011 | 11:36 AM
Xenolith666
Forgive my newbness.. but do I really need dampening? That's just for giving the wheel some 'angle' to it right? Or is that camber.. Eventually with the offsets I'm going for (32mm, 45mm) I shouldn't need dampening?
Old Jul 3, 2011 | 12:32 AM
POLLO's Avatar
POLLO
No you do not need dampening, however it is nice to have if you ever plan to do something other than lowering, or wish to have more adjustability to your setup. Regardless which do you end up taking, the good this is that the shocks have been matched with springs taking into consideration the height adjustment settings.
Dampening on the shock absorber is nothing more than the stiffness of the shock during shock travel under force. A soft setting will cause the shock to easily compress where a hard setting will cause the shock to compress at a much slower rate than the soft setting using the same force. All you are adjusting is how hard or soft the dampening is on the shock.
What gives the angle/camber to the wheel is the use of lower camber arms on the rear, or adjustable upper arms on the front of the car which are entirely different components from the shock absorbers and springs. Lowering the car will alter the camber settings.
I opted for the Tanabe Sustec Pros S-0C, however you can get the BC Racing Coils which are adjustable for not a whole lot more. But if all that you are looking for is to have adjustable ride height, you will be fine with the Tanabes.
timc00k
Feb 15, 2017 09:15 AM
optikol
Jan 28, 2016 07:31 PM
EnYcee-G
Oct 4, 2015 09:27 PM
BurtoN86
Sep 30, 2015 03:32 AM
