While we are talking about front end noises.
Old Feb 21, 2011 | 12:53 AM
TVPostSound's Avatar
TVPostSound
If you use an aftermarket sway bar that requires the factory rubber bushing:
DO NOT lubricate that bushing. Rubber bushings are designed to bind the sway bar, not allow it to rotate. If a rubber bushing is noisy, its worn out and must be replaced.
Only urethane bushings should be lubed.
Troop12
May 9, 2018 02:40 PM
m3clubracer
Sep 11, 2016 09:01 PM
Thedbarz
33
Feb 9, 2016 12:05 AM
ddayeg37s
Aug 9, 2015 07:10 PM
