Help Rear suspension: front lower link
Old Feb 4, 2011 | 02:32 AM
redrover23's Avatar
redrover23
If I remove the front lower link on rear suspension, can I remove the supporting jack on the rear lower link (that was used for removal)?
Based on the FSB, a jack is required to relieve spring pressure which will allow removal of the front lower link. I would like to do additional work while the front lower link is removed without the jack in place. Is this possible without causing damage or violating best practice?
BTW, my car will be on a scissor lift.
TIA!
Old Feb 4, 2011 | 11:05 AM
redrover23's Avatar
redrover23
Please advise so my weekend project can go forward!
Old Feb 4, 2011 | 11:17 AM
Modme's Avatar
Modme
Yes, just jack up the rear lower link and unbolt it. Then lower it slowly and relieve the spring load and take out the spring. Then you can take out the jack and do whatever you need with it.
Old Feb 4, 2011 | 11:20 AM
redrover23's Avatar
redrover23
Thanks for the reply. I'm referring to the front lower link, the arm that influences camber. Can I remove that arm and let the rest of the suspension hang, or does the main lower link need to be supported while the front lower link is removed?
TIA.
Old Feb 4, 2011 | 11:21 AM
Modme's Avatar
Modme
No, it doesnt need to be supported. The upperlink and the shock will keep everything supported. Just dont put too much weight on it. I installed my own coilvers and the camber arm you are referring to.
Old Feb 4, 2011 | 11:31 AM
redrover23's Avatar
redrover23
Appreciate the reply. I'll be doing my camber arm and 6 pt GT Spec brace this weekend.
I was considering removing the front lower arms, then installing the brace, followed by the camber arm installation.
Old Feb 4, 2011 | 11:37 AM
Modme's Avatar
Modme
That should be no problem. Just be careful when getting under the car. Make sure your scissor lift has the car securely supported. Either have someone help you or periodically check up on you. I've read quite a few stories of the car falling down on people in general.
Old Feb 4, 2011 | 11:46 AM
redrover23's Avatar
redrover23
Definitely. I'm careful when working under my car and even make sure someone is around, just in case. Thanks again.
Old Feb 4, 2011 | 02:08 PM
redrover23's Avatar
redrover23
I'm not sure the rear suspension has an upper link.
Old Feb 4, 2011 | 02:14 PM
Modme's Avatar
Modme
The manual calls it a suspension arm. It's labeled as number 1. Also the radius rod will help hold it up as well.
Old Feb 4, 2011 | 02:50 PM
redrover23's Avatar
redrover23
Got it. THX!
G's
Nov 5, 2023 12:01 PM
G37xhibeet
Nov 15, 2016 09:29 AM
Thedbarz
33
Feb 9, 2016 12:05 AM
Intake
Dec 25, 2015 09:38 PM
xpcgamer
Aug 10, 2015 03:43 PM
