Help Brembo brakes
Old Jan 21, 2011 | 06:42 PM
dexhax's Avatar
dexhax
Brembo brakes
How can i tell if a brake caliper will bolt up ? or how do i modify them to fit ?
(looking at porsche calipers from the cayenne ) Thanks much -Rob
Old Jan 21, 2011 | 07:01 PM
rAiN's Avatar
rAiN
just need brackets
Old Jan 21, 2011 | 07:12 PM
dexhax's Avatar
dexhax
Do you happen to know how i would find them and the rotors i need ? Thanks
i just checked and the stock cayenne rotor is 13 in diameter so would i be able to fit a larger rotor? would they fit my stock rotors or aftermarkets? Im clueless with brake setups
Old Jan 22, 2011 | 05:00 AM
6mtg37s's Avatar
6mtg37s
Why do you want cayenne caliper? Do you have the stock akebonos? And your better off buying a bbk designed for this car, it will be cheaper and easier to install.
Old Jan 22, 2011 | 07:04 AM
soundmike's Avatar
soundmike
I would suggest learning more before going this route or even attempting it. There's more to brake work than just bolting on a bigger set of calipers. Do it wrong and you'll have the worst brake bias you've ever experienced.
This is oversimplifying, but for one you may want to get hold of that Porsche-specific caliper, measure piston sizes, the OEM bias, then compare it against your OEM set-up.
Old Jan 22, 2011 | 04:43 PM
APRacing-ChrisB's Avatar
APRacing-ChrisB
^^^ What he said.
Kojack
Oct 9, 2015 05:53 PM
Mattimus
Oct 4, 2015 01:33 PM
Bennyjoel
Sep 30, 2015 11:56 PM
Soccer4555
Sep 30, 2015 05:31 PM
VIVID
Sep 27, 2015 09:45 AM
