Funny sounds when turning left after coilover instal
Old Dec 29, 2010 | 02:36 AM
Steveo47's Avatar
Steveo47
So when im going like... >10km an hour, i get a kinda of a pop sounds when i turn the wheel about 3/4 to the left. When i turn the wheel back the other way, there is no poping back noise. When i way doing the coilover instal i somehow (dont ask) removed some of the silicone form the sway bar endlink ONLY on the left drivers side front wheel (which is where the sounds is). Could this just be the sway bar making he noise? if i drive anything over 10km i cant hear anything
Old Dec 29, 2010 | 09:22 AM
Kidcane's Avatar
Kidcane
Florida G Club
Well if it makes noise only from the side that you removed the silicone from that is probably it but did you also check to see if your endlinks were nice and tight?
Old Dec 29, 2010 | 12:43 PM
Steveo47's Avatar
Steveo47
I triple checked each bolt. Never done suspension before so I wanted to be extra carful. It sous be very tight but I'll do a 4th check today when I raise the care a bit. Any idea where to get some new silicon?
Old Jan 7, 2011 | 10:29 AM
infamousstunna1's Avatar
infamousstunna1
is this the same noise that floating rotors make?
Old Jan 8, 2011 | 12:21 PM
Steveo47's Avatar
Steveo47
I figured it out. My camber arm wasent in all the way
GW330
Feb 2, 2024 05:41 PM
superjoey
31
Mar 22, 2023 11:56 PM
kevinmward
Aug 12, 2015 12:09 AM
