my alignment stats after lowering (pics)
ok so i had my car lowered on the bc coils as you may all know from my last few posts. im getting this wobble at take offs from a dead stop but only a gentle take off. its where the steering wheel seems to shake left to right very quickly for a brief moment and then doesnt do it after i am rolling. i also keep throwing a wheel weight for some reason which is driving me insane. im posting my alignment specs to see if anyone has any input on the numbers if anything should be changed. im currently dropped to 26 1/2" from floor to fender all around, running a 9 setting on dampening in the front and 14 in the rear, car seems pretty bouncy but plush. and when i harden it up just a little i start to hear every bump in the road and FEEL IT!!!
im running adjustable A arms up front and camber toe arms in the rear. so adjustability is really not a problem. any opinions would be great thanks.
Did they purposely set your rear camber at 2.4 degrees? Mine is an RWD and specified range for mine is -1.3 to -0.3.
I did notice that your sheet says modified spec. Maybe its just different specs for AWD?
