Eibach springs on a G37xS with front chin?
Old Aug 31, 2010 | 04:30 PM
SindhiStyle's Avatar
SindhiStyle
what do they mean when they say will need a "PRO-KIT will require PRO-ALIGNMENT kit 5.72265K or 5.72260K installed to adjust alignment to OE specification"
How much is this kit? anyone have part numbers? Is this the same as a basic alignment you get done at belle tire? or do they need a specific part?
Old Aug 31, 2010 | 04:43 PM
acm25's Avatar
acm25
Those ARE the part numbers for the front and rear camber kits. They provide additional camber adjustablity when doing an alignment. You'll most likely need those to get the alignment back to stock specs.
Old Aug 31, 2010 | 05:10 PM
TheLocNar's Avatar
TheLocNar
I'm not sure the front camber kits will fit?
Old Aug 31, 2010 | 06:35 PM
acm25's Avatar
acm25
I believe the fronts will fit the X. According to the Eibach and SPC sites (SPC makes the parts for Eibach), they fit on AWD sedans too. SPC Application Search - Product
The part #s in the earlier post are actually for rear camber kits, the front part # for Eibach is 5.72130k
Old Aug 31, 2010 | 06:46 PM
SindhiStyle
any idea how much the camber kits normally are? I tried to look on the eibach website and couldnt find the kits....maybe Im looking at the wrong place. I figured it would be with the springs??
Old Aug 31, 2010 | 06:56 PM
TheLocNar's Avatar
TheLocNar
Give nick at TH Motorsports a call. He will give you the best price.
Glad to know the camber kits also fit the X!
Old Aug 31, 2010 | 09:03 PM
qb37Xs's Avatar
qb37Xs
Originally Posted by leeI35G35
That info is not correct. 6379 is for a nissan versa. I just called Eibach. They have springs for the G37X coupe but nothing for the G37X sedan. They never got a G37 Sedan to test since they are located in CA. HOWEVER, they do have springs for the G35X Sedan which just came out #6399.140.
Eibach tech stated that the all vendors should have the AWD springs for the G35X by now. I am going to place an order since the G35X and G37xS are not that far off in weight and should have same suspension hardware.
^ Thank you very much, now the work begins. Glad I didn't install the RWD sedan springs I've had since April.
Old Mar 11, 2011 | 03:56 PM
foma's Avatar
foma
I have a 2010 G37xS Sedan, looking for a drop.
Will Eiback G37xS COUPE lowering springs work?
G's
Nov 5, 2023 12:01 PM
G37xhibeet
Nov 15, 2016 09:29 AM
m3clubracer
Aug 26, 2015 07:36 AM
drkashifa
Aug 18, 2015 04:38 PM
Ghost90
Aug 5, 2015 11:19 AM
