Knocking after eibach pro kit
Old Feb 22, 2010 | 02:31 PM
ortizstephen's Avatar
ortizstephen
After I had my springs installed there was some knocking when I would go over speed bumps or small holes. The shop said it's normal. It's been over three weeks and it's still doing it, just not as loud. Is this normal or is there a solution?
Old Feb 22, 2010 | 02:33 PM
xref's Avatar
xref
Not normal. Take it back.
Old Feb 22, 2010 | 02:42 PM
ortizstephen
Forgot to add that I jacked the car up and checked all the nuts and bolts to make sure nothing was loose. Everything seems ok...
Old Feb 22, 2010 | 03:29 PM
ucla bruin's Avatar
ucla bruin
By knocking do you mean creaking/rattling? I've had that too, put the car on the lift, checked everything. Brought it back down and it was fine. Apparently the springs weren't sitting right.
__________________
Old Feb 22, 2010 | 03:44 PM
ortizstephen
Yes, rattling is a better description. So u didn't have to tighten anything up? The lifting fixed the problem?
Old Feb 22, 2010 | 03:52 PM
ucla bruin's Avatar
ucla bruin
No tightening. Everything was good when double checked. The explanation was that sometimes the spring isn't seated right, so lifting it off, taking the weight off them. Then lowering it back down did the trick.
Good luck.
__________________
Old Feb 22, 2010 | 04:41 PM
blueborat's Avatar
blueborat
Good luck.
Mine was doing the same thing and lifting the car and set the car down again did the trick as well.
Old Feb 22, 2010 | 04:44 PM
Xcalibur's Avatar
Xcalibur
Exclamation
Nope not Normal! Take that back!
Old Feb 22, 2010 | 04:50 PM
ruckus12251985's Avatar
ruckus12251985
definitly get that checked out immediately it is not normal, the guy at the shop is an idiot if he thinks your suspension rattling is normal
Old Feb 23, 2010 | 11:05 AM
ortizstephen
Thanks for all the help. I will try this out!
Old Feb 23, 2010 | 11:16 AM
myk1013's Avatar
myk1013
Yeah, NOT normal!
I had the same problem on my front driver side after backyard installing my Eibachs as well.
Had it checked at a shop and the mechanic said it wasnt set well on the bushings and the bolt wasn't torqued to specs. (Didn't have a torque wrench)
I suggest not to go back to that shop who said that was normal
Old Feb 23, 2010 | 02:13 PM
goomba's Avatar
goomba
Spring may not be preloaded or seated correctly, piston rod nut is not tightened all the way which will cause top hat to rattle. Take it back.
VQCrew
Sep 26, 2015 01:19 PM
DiegoMontoya
Sep 22, 2015 11:05 PM
EnYcee-G
Sep 3, 2015 04:35 PM
Andyg90
Sep 2, 2015 06:10 PM
