2009 G37X coupe brake upgrade to factory akenbono's?
Old Aug 15, 2009 | 09:10 AM
cconklin1's Avatar
cconklin1
Alright, I have an x coupe and as most of you know it has the puny brake system. What I want to know is if anyone here has upgraded their X coupe to a better braking system, akebono or otherwise. If so, did you notice a big difference and where there any issues because of the all wheel drive? And before, I get flamed, I DID do a search and came up dry. Any help is appreciated in making this decision...
Best,
chris
Old Aug 15, 2009 | 09:56 AM
G37Sam's Avatar
G37Sam
Yup I believe Alto bought the Sports brakes and will install them soon, you can PM him for more info
Old Aug 15, 2009 | 10:27 AM
Alto101's Avatar
Alto101
I have the Akenbono kit sitting in my garage right now. I am going to get the new calipers powder coated before I have it installed. I have a G37x sedan but I do not think there is any difference between the sedan and coupe as far as the brakes are concerned.
I also changed my stock 17" wheels with all season tires to 19" with summer tires and I have to say the braking performance is 100% better even with the tiny OEM brakes If you are running OEM all season tires that is something that you might consider as well.
Once I get the akenbono kit installed I will post pictures as well as an update on the brake performance. Let me know if you have any more questions.
Best,
chris
Old Aug 15, 2009 | 10:31 AM
da mayor's Avatar
da mayor
plenty of members upgraded to the akebonos and has helped a lot. just make sure you have wheels that will clear the calipers
Old Aug 15, 2009 | 10:56 AM
Alto101's Avatar
Alto101
Good point, that is why I got the 19's so quickly. The 17's on the sedan definitely will not clear the calipers but I have been told that 18's or bigger will be fine.
Old Aug 15, 2009 | 01:06 PM
2009G37's Avatar
2009G37
How much did these brakes cost?
Old Aug 15, 2009 | 01:17 PM
Alto101's Avatar
Alto101
This is where I got mine from....
http://conceptzperformance.com/Cart/...574.138.26.228
Old Aug 15, 2009 | 01:20 PM
jnguyen's Avatar
jnguyen
Might be cheaper on Everythingg35.com because it comes with motul rbf300 brake fluid too
Old Aug 15, 2009 | 01:23 PM
Alto101's Avatar
Alto101
Don't forget the SS brake lines
I have heard this makes an improvement over stock.
Old Aug 15, 2009 | 10:08 PM
cconklin1's Avatar
cconklin1
Yeah, since the brakes are already off I would do the SS lines as well. I, too, was looking at having them powder coated before an install, but am hesitant about tearing up a new coupe when no one else has doen it first! I just KNOW there will be something different between the coupe and sedan, I just KNOW it!
I admit, in this instance I wish to be a "follower" instead of a "leader"!
I did have good luck when I opened up my steering column and saw I was pre-wired for paddle shifters though....
Now, if I can just figure out the damn offset of these wheels....
superjoey
31
Mar 22, 2023 11:56 PM
b2autodesigns
Brakes/Suspension
128
Mar 24, 2018 07:44 PM
Eli1223
Aug 12, 2015 06:34 AM
Ihtbealexxx
Aug 9, 2015 03:30 AM
