G37 lowering database
Old Jul 27, 2010 | 04:01 PM
  #31
Ahujadaddy's Avatar
Ahujadaddy
thanks guys!
and thanks J for updating the first post as well.
now to figure out how to adjust coil overs to get the height i want...
Old Jul 27, 2010 | 10:17 PM
  #32
TVPostSound's Avatar
TVPostSound
2010 G37S Coupe
Eibach PK
26 1/2" front
26 3/4" rear
Stock 19" Sport Wheels and Tires
20mm spacers all around
No rubbing
Drop even side to side!!!
Old Nov 5, 2010 | 09:50 PM
  #33
swizz70's Avatar
swizz70
2008 G37S coupe
Eibach Pro kit
SPC Front Camber kit
ride height: not measured yet
Volk GT30 19X8.5 +36 T1R 245/40/19
Volk GT30 19X10.5 +37 T1R 275/35/19
No rub
Is your drop even side to side: not measured yet
Old Dec 21, 2010 | 12:23 PM
  #34
1cleanG's Avatar
1cleanG
NextLevel Performance
To everyone that posted all of their specs without offsets, your post is absolutely worthless to this thread.
I was looking through trying to get an idea of what offsets I want for my next wheel...first page was great...and then just died off w/ no offsets. I'm currently running the typical
20x9.5 +35
20x10.5 +37
but am looking to go more agressive in the front possibly. I'm slammed on KW's w/ front & rear SPC kits
Old Mar 23, 2011 | 11:01 AM
  #35
joebeast's Avatar
joebeast
08 G37S coupe
Suspension: Tanabe Sustec Pro S-OC with SPC front/rear cambers
Height: 25.25 front, 25.75 rear
Wheels: 19" stockie
Tires: 245/40 front, 275/35 rear
Rubbing: No, but extremely sensitive to uneven surfaces haha
Old Aug 6, 2011 | 12:23 AM
  #36
fashionrider712's Avatar
fashionrider712
could you guys also add in your allignment specs if any, with which type of allignment kit pls.
Old Aug 6, 2011 | 01:19 AM
  #37
driftz's Avatar
driftz
Thanks for this thread. Appreciate it very much.
Old Aug 18, 2011 | 01:42 PM
  #38
rpm&my_G35's Avatar
rpm&my_G35
...more sedan info would be great, including alignment info
Old Oct 3, 2011 | 02:14 AM
  #39
OMG35S's Avatar
OMG35S
PLEASE STICKY THIS!!!
I'm thinking about lowering it before I go in for an alignment but I'm not sure... Might just leave it as is until after winter.. What do you guys think?
2007 Infiniti G35s Sedan 6mt 4WAS
BC Racing Coilovers
26.75" all around (Front drop - 1.4") (Rear drop - 1.01")
Stock Staggered Sport OEM 18's with 20MM H&R Spacers
No rubbing
Even all around with 1/2 tank of gas and empty car/trunk
Old Oct 3, 2011 | 06:45 AM
  #40
guamspyder's Avatar
guamspyder
2008 coupe s
suspension:370z springs( i think im the only one running Z springs)
ride height:26.5(f) 26.5(r) (fuel tank is FULL so after fuel goes down...rear raises a lil)
rims: Axis super hiro 19"
wheels:19x9.5(f) 19x10.5(r) i forgot the offsets
i barely drive my car...maybe once a month but i did scrape once cause of a HARD dip
yeah its pretty even all around somedays pending on fuel, n tire pressure
Old Oct 9, 2011 | 09:01 PM
  #41
joebeast's Avatar
joebeast
'08 Coupe
Suspension: Tanabe Sustec Pro S-0C coilovers
Ride height: 25.0" Front 25.0" Rear (3in dropped from stock height)
Tire/wheel size: Stockies 245/40/19 Front w/25mm spacers - 275/35/19 Rear w/20mm spacers
Extremely sensitive to rubbing, especially the rear. (Will trim fender liner and bracket)
Even all around
Old Oct 17, 2011 | 10:26 PM
  #42
  • Coupe or Sedan ~09 G37 Journey Sedan
  • What suspension are you dropped on? ~B&G S2 springs
  • What's your ride height (the measurement from the ground to the highest point of your fender opening in the center)?
    ~25.7" Front / 26" Rear 2.2" drop front, 1.5" drop rear
  • What are your wheel and tire sizes/offsets ~20x8" w/38 offsets
    245/35/20 tires
  • Do you rub? ~No Rubbing
  • Is your drop even side to side? Yes
  • SPC camber arms F&R alignment in OEM specs
  • Pic thread below~
Anyone tried B&G S2 Sport Springs? - G35Driver
Old May 2, 2012 | 05:40 PM
  #43
Q8y_drifter's Avatar
Q8y_drifter
08 G35 sedan
Tanabe coilovers
*Yet to be measured
19x8.5F +35 / 19x9.5R +36 (offsets might be other way around, but whatever)
245/40/19F 285/35/19R
Rear rubs on speed bumps and going sideways on a steepish driveway.
Somewhat even. Driver's side is about 5~6mm lower.
Stock camber + toe
Edit: just noticed this thread is a bit old. Oh well.
Old May 6, 2012 | 11:01 AM
  #44
rpm&my_G35's Avatar
rpm&my_G35
2011 G37S Sedan
  • Vehicle: 2011 G37S 6MT Sedan
  • Supension Mod: Eibach Prokit #6390.140
  • Alignment: See the attached. No Camber Kit parts - 100% OEM
  • Ride height: Front = 26 5/8", Rear = 26 1/2" (with 1/4 fuel)
  • Wheels/Tires: 20x8.5 +37 & 20x10 +48, Gunmetal DPE R16 with Hankook Ventus V12. Wheels easily clear the factory Akebono BBK.
    Also have Michelin X-Ice Xi2 winter tires mounted on stock Enkei 18"wheels.
  • No Rubbing, no scraping entering driveways or over 'normal' 2"-3" speed bumps.
  • Total lowering cost incl: springs, labour, alignment. $440 CAN
See My Garage for some pics.
Attached Thumbnails G37 lowering database-alignment-my-current-on-eibach-pro-kit.jpg
Last edited by rpm&my_G35; Jul 16, 2012 at 02:33 PM. Reason: added alignment specs sheet
Old Jul 20, 2012 | 11:46 PM
  #45
4rnr's Avatar
4rnr
Great thread, may I make a request as a new guy, to add one picture of your ride.
It will help us noobs to see what each looks like.
