StopTech SS Line Install and Pictures
Old Apr 25, 2009 | 04:43 PM
HamstersG's Avatar
HamstersG
One of the easiest things to do actually. The instructions were pretty good, but they use a 350Z for the instructions. When you disconnect the OEM brakeline from the car hard line, they have given you a rubber cap to seal off the hard line to minimize brake fluid lose. Mine sat there over a week while rotors getting PC'd and no problems. The rubber cap is in the red circle below.
Here are the OEM and StopTech front brakelines on the ground together.
I didn't follow the instructions exactly. I connected the line to the caliper first which made it easier to align the line where I wanted. Then ran the line up and connected it to the hardline.
Connected the two line mounts to the OEM mounting bolts per instructions.....done.
Old Apr 25, 2009 | 04:54 PM
SOLISIMO's Avatar
SOLISIMO
so how does she feel?
Old Apr 25, 2009 | 05:25 PM
jnguyen's Avatar
jnguyen
Originally Posted by HamstersG
LMFAO NICE TEASER, those calipers look sick!!!
Old Apr 25, 2009 | 05:38 PM
HamstersG's Avatar
HamstersG
Don't know yet. Not got it out of the garage yet. Just got tired of working on it so posted this after doing the fronts.
Old Apr 25, 2009 | 05:42 PM
SOLISIMO's Avatar
SOLISIMO
Cool man!
Old Apr 25, 2009 | 05:47 PM
VRG37S's Avatar
VRG37S
Looks great...Thanks for the DIY info... I will be doing this to my car as well soon...Calipers look great tooo...Who did them and how much did it cost if you don't mind...THANKS!!!!!!
Old Apr 25, 2009 | 05:48 PM
elite's Avatar
elite
very nice. good write-up.
thx!
Old Apr 25, 2009 | 06:33 PM
HamstersG's Avatar
HamstersG
Mike @ http://www.thepowdercoater.com/
Old Apr 25, 2009 | 07:33 PM
Kidcane's Avatar
Kidcane
Florida G Club
Mike strikes again. Very nice. Did you upgrade to the better fluid too?
Old Apr 25, 2009 | 09:19 PM
HamstersG's Avatar
HamstersG
Not yet. Going to flush once I have everything back together, working, etc.
Old Apr 25, 2009 | 10:07 PM
wakeboardr116's Avatar
wakeboardr116
Looks good. So can you put these in and just go from there or do you have to do anything to the brakes since you disconected the hoses. Can air get in and affect anything? I guess what i am asking is could i order these install them myself then drive somewhere and get the system flush and higher temp fluid put it.
Old Apr 25, 2009 | 10:19 PM
HamstersG's Avatar
HamstersG
You could order them and install yourself, but you will have to bleed them to get the air out before you drive. Bleeding brakes is a snap if you got a helper some tubing and platic bottle, otherwise you need a bleed kit. Go here and look at the brake section for help. http://g35driver.com/forums/g35-seda...eo-series.html
Old Apr 27, 2009 | 05:35 PM
Ivoidwarranties's Avatar
Ivoidwarranties
That is one of the best looking brake setups on this site.
Old Apr 27, 2009 | 11:53 PM
HamstersG's Avatar
HamstersG
Thanks. I take all compliments even if it is becasue I picked your favorite color.
Old Apr 28, 2009 | 12:10 AM
Ivoidwarranties
True, I like the red but I like the detail put into the rotors. That's the level of detail that's not normally put into these cars.
