View Poll Results: What is your sway setting?
Softest
4.35%
Medium
12
52.17%
Stiffest
43.48%
Voters: 23. You may not vote on this poll
Hotchkis Sway settings
Old Apr 22, 2009 | 02:32 PM
SilverBullet's Avatar
SilverBullet
Originally Posted by oOmikeyboy
From Andy@HPA. the springs just stiffen the ride a little bit and lower the car. I would probably go with Medium on the eibachs just to keep it subtle and not too aggressive.
What do you mean by lower and aggressive? When I drive it now, I feel that it could be a bit more stiffer.
Old Apr 22, 2009 | 02:37 PM
oOmikeyboy's Avatar
oOmikeyboy
Well,
Like the Eibachs' are just springs..which serves the purpose of lowering the car and providing a more "firm" suspension. They aren't coilovers so your not getting much performance out of the Eibachs.
When you add the hotchkis sway bars, you will be stiffening the suspension via sways. If you have a non-S and you go to hotchkis, you will be stiffening it by 175%, which is quite substantial. Also bear in mind that these adjustments are not permanent, meaning you can always go softer or stiffer in the future.
If you feel thats not enough, you can always go to the stiffest setting (250%) or the softest, 120%, which should still be noticeable.
Old Apr 22, 2009 | 02:44 PM
SilverBullet
Well,
I have a sport and I do feel a slight difference since getting the sways, but I thought it would be more of a difference. So Im thinking I need to be stiffer.
Old Apr 22, 2009 | 02:56 PM
oOmikeyboy's Avatar
oOmikeyboy
Oh, then yeah definitely try the stiffest setting and see if its suitable.
Old Apr 22, 2009 | 03:01 PM
SilverBullet
I am going to try and pick up some ramps today and try to change the settings.
Old Apr 22, 2009 | 03:07 PM
wakeboardr116's Avatar
wakeboardr116
What i dont get is how the rears can only be 65% stiffer while the fronts make it 205% stiffer, this being on a sport. The numbers just dont seem right, thats a huge difference between the two. The stillen sways claim about the same in rear (70%) but only like 40% in the front.
Old Apr 22, 2009 | 03:13 PM
kkokko's Avatar
kkokko
also, if it's too stiff... would it make the ride harder? or..... just more oversteer?
Old Apr 22, 2009 | 03:14 PM
xyz's Avatar
xyz
I have the eibachs and I am on medium. I want to try out the stiffest setting though.
Old Apr 22, 2009 | 03:16 PM
kkokko's Avatar
kkokko
any non sport with eibachs?
Old Apr 22, 2009 | 03:51 PM
finagle69's Avatar
finagle69
I am on Stillen sways and can comment to stiffnesses:
I'll caveat this with the fact that I'm on coilovers, so not true apples-to-apples.
The fronts of the Stillens compared to the stock SPORT bar is 28.6% stiffer. I feel that this could be much much stiffer, maybe not 205% like the Hotchkis, but somewhere between 100 to 150% stiffer would be much better.
The rear bar is 70.4% stiffer than oem SPORT bar at the stiffest setting, and I'll say that it is just a tad too much, making the car oversteer far too quickly and often. I've tried them on the softest setting, which is 37% stiffer than the oem SPORT bar, and that is just not quite enough, with the rear end being a little more squirly than I'd like.
If you're wondering about what to use for the rear, skip soft and medium right up and try for hard. It'll probably be perfect.
Old Apr 22, 2009 | 05:04 PM
SilverBullet
I am planning on adjust it to the stiffest to see if I like it. The stiffest setting is the bottom hole, correct?
Old Apr 22, 2009 | 05:16 PM
oOmikeyboy's Avatar
oOmikeyboy
From Black Betty's DIY. The innermost hole is the one you want.
Old Apr 22, 2009 | 05:50 PM
SilverBullet
Thanks for the info.
Old Apr 22, 2009 | 06:23 PM
  #29
splitmx's Avatar
splitmx
So you can use the stock endlinks with these?
Old Apr 24, 2009 | 09:03 PM
  #30
SilverBullet
I like to hear more from those who have the stiffest setting on Hotchkis sways. How do you like it? If you had it on medium setting and then switched, what do you think of the difference? Is there a lot of oversteer? How is the handling on the twisties?
