Help Eibach pro kit question for the handling guru's
Old Feb 9, 2009 | 03:07 PM
DanMardik's Avatar
DanMardik
Smile Eibach pro kit question for the handling guru's
Been doing some research on the Eibach Pro Kit and it looks like the drop for our cars on that kit is roughly 1.4" in the front and 0.8 in the rear.
Since there is more of a drop on the front and Although that's good for eliminating the gap in the front wheels, wouldn't that mean that you would be shifting the weight of the car forward hence causing some handling changes in the cars behavior for the worse?
Food for thought.. what do you all think?
Old Feb 9, 2009 | 03:12 PM
iiiiiekoiiiii's Avatar
iiiiiekoiiiii
its a pretty even drop on g37s cause your rear already sits lower then the front.
Plus if u put more stress on your rear shocks, they'll get bouncy a lot sooner. fronts are struts so they take the beating a lot better.
Old Feb 9, 2009 | 03:14 PM
DanMardik's Avatar
DanMardik
Thanks for your input.. Anyone else?
Old Feb 9, 2009 | 03:15 PM
iiiiiekoiiiii
Just do it
Old Feb 9, 2009 | 03:39 PM
Ivoidwarranties's Avatar
Ivoidwarranties
I know what you are trying to get at and in theory you are heading in the right direction on your point. Fact of the matter is, it is probably so negligible that there is no way to measure it. I guess you could always test weigh a car on all four corners before and after installing the kit. I bet there would be no shifting of the weight. The car is too low to begin with for that to happen.
Old Feb 9, 2009 | 05:23 PM
w0ady's Avatar
w0ady
1/2" doesnt seem like enough to really matter. still has the same amount of weight over each wheel.
Old Feb 9, 2009 | 08:37 PM
DanMardik's Avatar
DanMardik
Sure, but even 1% weight shift forward would make for a more twitchy car... no?
Old Feb 9, 2009 | 08:44 PM
Ivoidwarranties
Let's say it does drop 1.4"/0.8". That is a 0.6" difference in the front. Now let's try to figure out the angle on that and how much weight is shifted... who am I kidding? I can't figure that out right now. How much is 1% of the car weight? 35-40 pounds? I can tell you right now that's not going to happen.
But you are correct in your theory.
Old Feb 9, 2009 | 08:53 PM
DanMardik's Avatar
DanMardik
I think in order to get a base, we need to find out how the car sits from the factory, or I can just ask all of you who really push their cars with the Eibach Pro kits how you like the feel of the car with this set up...
Old Feb 9, 2009 | 08:56 PM
ucla bruin's Avatar
ucla bruin
The handling and behavior in corners have improved after I got my Eibachs. You can use me as actual case study data as opposed to theoretical calculations
__________________
Old Feb 9, 2009 | 08:57 PM
DanMardik's Avatar
DanMardik
Originally Posted by ucla bruin
The handling and behavior in corners have improved after I got my Eibachs. You can use me as actually case study data as opposed to theoretical calculations
Thanks for the input. Do you ever drive at the limits of your cars handling potential, or do you just take a few hard corners here and there?
Old Feb 9, 2009 | 09:01 PM
sTiLLBaLLiN37's Avatar
sTiLLBaLLiN37
Former Prez of LA G'Z
Handling is significantly improved with the Eibachs, however that may be because I have sways too haha.
Old Feb 9, 2009 | 09:02 PM
ucla bruin's Avatar
ucla bruin
Haven't had a chance to push it near the brink since I got the Eibachs, but will look to soon before I put on new wheels in 2 weeks or so.
I think if you're looking to track or push to the full potential often, I'd suggest coils instead of springs.
__________________
Old Feb 9, 2009 | 09:05 PM
DanMardik's Avatar
DanMardik
Does your car feel more neutral with this set up? or does it under/over steer?
Very kool, let me know what you come up with in terms of the overall balance of the car handling.
Old Feb 9, 2009 | 09:06 PM
ucla bruin's Avatar
ucla bruin
How about coils, since it seems you focus a lot of handling down to the T.
__________________
