Hotchkis sway bars v.s. Stillen sway bars
Old Aug 10, 2009 | 07:14 PM
  #46
sredish's Avatar
sredish
yes, do it.
Old Aug 10, 2009 | 07:36 PM
  #47
pdarby's Avatar
pdarby
Yea, did it. They go on in the morning. Sorry to hear that "quart" is giving up his G.
PD
Old Aug 11, 2009 | 02:00 AM
  #48
TJHG37S's Avatar
TJHG37S
Good deal, make sure to get rear Energy Suspension bushings as well, are the fronts ES bushings or just new stocks? $35 buys you a set (front and rear) of Poly bushings from EnergySuspensionPartsOnline.com, that's what I did for my Stillen sways and I love em
Originally Posted by pdarby
a friend of mine is turning in his G lease, for one reason or another. So I have the opportunity to buy his Stillen sways. He offered them to me for $175 with new, never used bushings for the front one. I think its a great deal, anyone?
PD
Old May 24, 2010 | 12:45 AM
  #49
dainjarouz's Avatar
dainjarouz
reviving.
Has anyone bought Tanabe Sustec Sways? They are new. Dont know if they are adjustable.
Old Jun 18, 2010 | 02:00 AM
  #50
Presto's Avatar
Presto
anyone with the tanabe sways here?
might as well add tanabe also to this comparison.
Old Jul 6, 2010 | 06:58 PM
  #51
TheLocNar's Avatar
TheLocNar
For the aftermarket bushings, are you guys going with greased or non-greased?
I am assuming the rear sways will fit the x sedan? I know the fronts won't work.
Old Jul 6, 2010 | 07:50 PM
  #52
hispeed-lowdrag's Avatar
hispeed-lowdrag
you need to grease the bushings. otherwise you will get some mad squeaking and could possibly run into other problems (I don't know about other problems for a fact but the noise will be super annoying)
Old Jul 6, 2010 | 08:13 PM
  #53
Ivoidwarranties's Avatar
Ivoidwarranties
Energy Suspension bushings used to work like this:
-black had graphite built in and were self-lubricating.
-red needed the urethane lube to be used with it.
Old Jul 6, 2010 | 10:15 PM
  #54
dainjarouz's Avatar
dainjarouz
FYI: eibach is coming out with sways soon. 2 way adjustable fronts and 3 way adjustable rears
Old Jul 6, 2010 | 10:18 PM
  #55
hispeed-lowdrag
hmm good info!! I still think Hotchkis is the best around
Old Jul 6, 2010 | 10:32 PM
  #56
dainjarouz's Avatar
dainjarouz
i think it might be too...ill probably go with those..the extra stiffness up front is good for the fat girl
Old Jul 18, 2010 | 10:59 AM
  #57
jwick's Avatar
jwick
Any have any problems with the factory end links when upgrading sway bars? If so, got a suggestion on aftermarket replacements?
Old Jul 19, 2010 | 10:32 PM
  #58
w0ady's Avatar
w0ady
running stillen sways for 1.5 years now with stock bushings and no issue. i track my car as well for what thats worth.
Old Jul 20, 2010 | 11:41 AM
  #59
godzilla619's Avatar
godzilla619
I hope you check your sway bars often for cracks then, because on the 350z forums a couple of members had them crack at the mounts.
Broken rear sway bar....... - MY350Z.COM Forums
Old Sep 22, 2010 | 03:37 AM
  #60
GraphiteG37S's Avatar
GraphiteG37S
Is it really needed to add new bushings when installing Stillen sways?
How difficult is the install?
