bedding in brakes
Old Jan 22, 2009 | 10:44 AM
2009G37's Avatar
2009G37
bedding in brakes
Hey guys,
Okay, so I know we don't have the most high performance brakes, nor will the majority of us go tracking with the G. However, do you guys still bed in the brakes when you get car, and what procedure do you recommend? Can this bedding in occur at any time, or are you screwed if you haven't done it in the first month and have already driven the car a few hundred miles?
Old Jan 22, 2009 | 10:48 AM
aliiin's Avatar
aliiin
BMW Defector
what does bedding me? excuse me, i'm a retard/noob
Old Jan 22, 2009 | 10:49 AM
daveindubai's Avatar
daveindubai
Bedding in the brakes
Originally Posted by 2009G37
Hey guys,
Ummm - I admit it - not a car junkie (except for my G37S of course!). Bedding in the brakes? What is this?
Have had the car for 3 days and some **** (many of them here) forced into my lane and I had to hit the breaks HARD - I kinda thought I felt abit of grinding...? If this to do with not bedding in the brakes and if so how do I do it?
Cheers
Old Jan 22, 2009 | 10:58 AM
2009G37's Avatar
2009G37
Okay so I guess since most of us don't do it, it's probably not necessary hahah. Found this on the net, which says with our Akebono brakes, we can just drive casually, similar to breaking in the engine. However, some places say all new rotors should be bedded. Take the GTR for example (way different car I know), it gets a 20 min bedding procedure at the Tochigi plant before delivery to the customer.
[ Email ] Brake Tech Information
<FORM name=selectform1 action=/brakes/tech/techpage.jsp method=get><SELECT class=techselect onchange=submit(selectform1) name=techid> <OPTION value="" selected>Additional Brake Tech Articles</OPTION> <OPTION value=86>All About Performance Categories</OPTION> <OPTION value=85>Brake Pad and Rotor Bed-In Procedures</OPTION> <OPTION value=80>Brake Pad or Rotor Inspection & Replacement</OPTION> <OPTION value=87>Brake Rotors and Track Use</OPTION> <OPTION value=78>Brakes 101</OPTION> <OPTION value=79>Choosing Brake Components</OPTION> <OPTION value=83>Cryogenics 101</OPTION> <OPTION value=89>D3EA® Brake Testing</OPTION> <OPTION value=81>Getting the Right Fit: Brake System Upgrades</OPTION> <OPTION value=84>The Finishing Touch: Brake Rotors</OPTION> <OPTION value=82>Understanding How Brakes Work</OPTION> <OPTION value=88>Why Ceramic Brake Pads?</OPTION></SELECT><INPUT type=hidden value=85 name=currentpage> </FORM>
Lea esta página en español
All brake pads must be bedded-in with the rotor they will be used against to maximize brake performance. The bedding-in process involves a gradual build up of heat in the rotors and pad compound. This process will lay down a thin layer of transfer film on to the rotor surface. Following the bed-in procedures provided by the manufacturer will assure a smooth, even layer of transfer film on the rotor and will minimize brake judder. Here are a few things to keep in mind when installing new rotors and pads:
When installing new pads, the rotors should be new or at least resurfaced to remove any transfer film from the previous set of brake pads.
It is critical that the installer clean any rust, scale, or debris from the hub mounting surface thoroughly and check it for excessive run-out with a dial indicator gauge before installing the rotor.
The new rotor should also be checked for excessive run-out using a dial indicator gauge before the caliper and pads are installed. If a rotor has excessive run-out of over .004" (.10mm) it should be replaced.
If your new rotor has excessive run-out, please contact our customer service department for a replacement rotor. Do not install and drive using the rotor! Rotor manufacturers will not warranty a used rotor for excessive run-out. Running with excessive run-out on the hub or rotor will cause vibration issues.
Failure to follow these procedures may result in brake judder, excessive noise, or other difficulties in bedding-in the new brake pads. The pads need a fresh surface to lay down an even transfer film. Residue from the previous pad compound on the surface or an irregular surface on a used rotor will cause the pads to grip-slip-grip-slip as they pass over the rotor surface under pressure. The resulting vibration will cause noise and telegraph vibrations through the suspension and steering wheel. This vibration is known as brake judder or brake shimmy. This is typically caused by an uneven transfer film on the rotor surface or an uneven surface on the rotor not allowing that transfer film to develop evenly. This is often misdiagnosed as a warped rotor.
Bedding-in new pads and rotors should be done carefully and slowly. Rapid heat build up in the brake system can lead to warped rotors and or glazed brake pads. Most brake pad compounds will take up to 300-400 miles to fully develop an even transfer film on the rotors. Following are the recommended bed-in procedures from each manufacturer:
AKEBONO
400 to 500 miles of moderate driving is recommended. Consumer should avoid heavy braking during this period.
ATE
BREMBO Gran Turismo
In a safe area, apply brakes moderately from 60mph to 30mph and then drive approximately 1/2 mile to allow the brakes to cool. Repeat this procedure approximately 30 times.
HAWK
After installing new pads make 6 to 10 stops from approximately 35 mph with moderate pressure. Make an additional two to three hard stops from approximately 40 to 45 mph. Do not allow the vehicle to come to a complete stop.When completed with this process, park the vehicle and allow the brakes to cool completely before driving on them again. Do not engage the parking brake until after this cooling process is compete.
NOTE: Hawk racing pads (Blue, Black, HT-10, HT-12) may require a different bed-in procedure. Contact your sales specialists at the Tire Rack for racing application information.
KAZERA
Follow the brake pad manufacturer's recommended break-in procedure taking care not to produce excessive heat in the system. Avoid heavy braking for the first 400-500 miles.
POWER SLOT
SATISFIED
For Gransport GS6 Carbon Ceramic Pads —
Step 1: Make 10 stops from 30 mph (50 kph) down to about 10 mph (15 kph) using moderate braking pressure and allowing approximately 30 seconds between stops for cooling. Do not drag your pads during these stops. After the 10th stop, allow 15 minutes for your braking system to cool down.
Step 2: Make 5 consecutive stops from 50 mph (80 kph) down to 10 mph (15 kph). After the 5th stop, allow your braking system to cool for approximately 30 minutes. This completes the break-in of your pads to the rotor surface.
During Steps 1 & 2, a de-gassing process occurs which may produce an odor coming from your pads as they complete the break-in cycle. This odor is normal and is part of the process your pads must go through to achieve their ultimate level of performance. The odor will go away after allowing your braking system to cool for approximately 30 minutes.
As with any new set of pads, do not tow a trailer or do any hauling during the break-in period.
Full seating of your new brake pads normally occurs within 1,000 miles.
For all other Satisfied pads —
Old Jan 22, 2009 | 11:00 AM
2009G37's Avatar
2009G37
The above was taken from tirerack.com btw.
Old Jan 22, 2009 | 01:17 PM
Gyoza's Avatar
Gyoza
So you answered your own post?
Old Jan 22, 2009 | 01:20 PM
CHI-TOWN G37's Avatar
CHI-TOWN G37
This is not a race car..................
Old Jan 22, 2009 | 01:33 PM
PSYH's Avatar
PSYH
Post Whore
I think he's asking for our opinion on the topic.
Old Jan 22, 2009 | 02:40 PM
2009G37's Avatar
2009G37
Well I obviously tried to search for the anwer myself before posting, but yeah, I wanted the opinion of people who have actually driven the G to see if bedding in is really a big deal for our "normal" cars.
Old Jan 22, 2009 | 04:02 PM
Serbiasrt8's Avatar
Serbiasrt8
beding in the brakes is a good idea.When installing new brake pads(in order to make them sit in the perfect position,also you leave a layer of film on your rotors which makes your pads grip better.
I have done this procedure numerous times with my SRT8 and let me tell you it was night and day difference.
The only problem is finding a stretch of road where you can do this without puting your self in danger.It is very important to not come to a complete STOP after you are done beding the brakes,you need to continue driving for a while before coming to a complete stop.That way you let the brake pads cool off and you won't leave an Imprint of your pads on the rotors and you will prevent your pads from sticking to the rotors.
Old Jan 22, 2009 | 09:11 PM
w0ady's Avatar
w0ady
you only need to bed them in when you install new pads. never heard of anyone doing it on a new car.
my technique is 3 sets of 10 - 60-10 mph stops with a cooldown between each set.
Kojack
Oct 9, 2015 05:53 PM
Mattimus
Oct 4, 2015 01:33 PM
Bennyjoel
Sep 30, 2015 11:56 PM
Soccer4555
Sep 30, 2015 05:31 PM
VIVID
Sep 27, 2015 09:45 AM
