Aftermarket dimpled/slotted rotors.
Old Jan 21, 2009 | 03:53 AM
g37RN's Avatar
g37RN
looks like be made in China, but I called Stillen and should have rotors ready for the G37S real soon.
Old Jan 21, 2009 | 11:56 PM
xcess torq's Avatar
xcess torq
Couple of items to remember when buying rotors. Those rotors may look cool but they will crack. ANY drilled rotor will crack eventually. Second, they most likely will not change your braking distance. They "may" improve your brake fade but as with any system, your pads and brake fluid require upgrading as well. Most of us who are never on a track will never encounter brake fade on the road. Meaning unless you have been on a track you have never experienced brake fade going into a corner.
Last item to note is weight of the rotor. Lighter rotors is less unsprung weight which is good. However this is bad in that the rotors cannot handle the heat load caused during heavy braking. Which is why you would want additional cooling to the rotor. However if the rotors are heavier than OEM, your handling will be impacted negatively.
You can't increase the size of the rotor diameter with the OEM caliper. Will not fit.
Powerslot rotors are dimpled and slotted which can give you that cool look without the risk of cracking. Don't know if they have a two piece rotor for lighter weight for the G.
Last item, if you buy rotors, buy new pads. Do not run old pads on new rotors. Save them as sets so that you can put them back on in the future. Keep the pads with the respective rotor and identify which was on the outside or inside of the caliper.
Of course all this is my opinion.
Old Jan 21, 2009 | 11:59 PM
C@ciQ's Avatar
C@ciQ
Thks for the facts.
Old Jan 22, 2009 | 03:21 PM
sahiwal007's Avatar
sahiwal007
is their a such thing as a black rotor?
Old Jan 22, 2009 | 08:33 PM
xcess torq's Avatar
xcess torq
Yes, until the first time you hit the brakes and remove all the coating. The hubs and inner airflow channels can be black.
Old Jan 22, 2009 | 09:16 PM
w0ady's Avatar
w0ady
i wouldnt do cross-drilled rotors personally. if you plan on pushing your car hard, they weaken the rotor. for show or daily driving, they are fine. for right now, the best option looks to be upgraded pads and stock rotors until someone comes out with something.
Old Jan 22, 2009 | 11:06 PM
HamstersG's Avatar
HamstersG
For looks, the Brake Performance ones are OEM rotors with slots/dimples. But too expensive IMO.
Old Jan 22, 2009 | 11:38 PM
Does anyone know here I can find larger than OEM rotors and will they work with the same calipers? The wheels I have now make the brake rotors look puny but the performance is fine, just want larger rotors.
Old Jan 22, 2009 | 11:44 PM
HamstersG's Avatar
HamstersG
Pretty sure you are out of luck unless you go with BBK. Solo has a new low price on his.
Old Feb 8, 2009 | 12:01 PM
atiek2's Avatar
atiek2
Brake Rotors for G37S
BrakeWorld.com has in my opinion a very nice set, they a Disc Italia 14" front 13.8" back. Made of high quality carbon steel. A little pricey at $900 front and rear. Also have Hyper Ceramic, and Titanium Kevlar pads at $200 front and rear. Will be ordering in mid March for spring.
Old Feb 8, 2009 | 12:27 PM
chamelieon's Avatar
chamelieon
oem calipers are spaced for oem rotors. anything larger will not work since it will not extend farther than the caliper will allow, or it will just grind at the metal. your only option is an aftermarket BBK.
ps- a bigger rotor does nothing if the pad size remains the same. all your adding is more weight.
Old Feb 8, 2009 | 02:22 PM
HamstersG's Avatar
HamstersG
Here is another option to consider.
https://www.myg37.com/forums/support...otorsport.html
Old Feb 8, 2009 | 02:39 PM
iiiiiekoiiiii's Avatar
iiiiiekoiiiii
dont buy ebay rotors lol. Especially with that many holes, You will crack the rotors.
Old Feb 8, 2009 | 02:52 PM
  #29
w0ady's Avatar
w0ady
ya you're out of luck for just a rotor swap. bbk would be your best option.
if you wanted to stay stock size, the rotora slotted would be best for performance and cross-drilled for show.
4DRZ
Engine, Intake and Exhaust
12
May 18, 2017 11:25 AM
ANMVQ
Dec 8, 2016 04:55 PM
parkern
Oct 5, 2015 12:12 PM
r0cketm0nkey
Intake and Exhaust
Sep 28, 2015 08:41 AM
