BC Coilover question:
Old May 29, 2008 | 04:07 PM
  #31
MaxToTheG37's Avatar
MaxToTheG37
Super Moderator w/ Boost
ah... i see
Old May 29, 2008 | 05:10 PM
  #32
1BADV6's Avatar
1BADV6
Has there ever been a real install guide put out? The included instructions in the box suck *** (engrish.com material!) so maybe it was mounted upside down? Max had his installed by Sharif, and mine by a local tech who is certified not to mention works on suspension installs daily so can't be a total moron. The guy measured the height and adjustments critically every time to ensure it was a perfect match on all sides so I'm not sure I want to blame him for not installing right. At the same time, with no instructions to double check, I will consider having him go through the install again. So are there any instructions?
Old May 31, 2008 | 05:42 PM
  #33
1BADV6's Avatar
1BADV6
Uhh, anyone have a writeup on the install?
Also need help with placing the rear adjusters through...where do they come out at? I can't find the top of the strut from the trunk side.
Old May 31, 2008 | 06:31 PM
  #34
IP37's Avatar
IP37
on the passenger side, take out your carpet and look at the shock tower.. there are two holes. you have to make one of them bigger. I think I used the one on the right.
then on the driver side I compared it to the passenger side and drilled a new hole
Old Jun 1, 2008 | 10:44 PM
  #35
1BADV6's Avatar
1BADV6
I keep seeing Pete from BC in this thread...but no answers??? What gives on the install instructions?
Old Jun 2, 2008 | 11:20 AM
  #36
Pete@BC's Avatar
Pete@BC
Sorry fellas, I have a few computers I work from and they never turn off. Even if I'm sleeping it still shows that I'm online at all times. I'm trying to find time to post these pics. I have to load the pics to our site and do a write up in between all the other things going on. I'm actually leaving for texas today because our f250 blew the tranny on the way back from modified magazines tuner shootout. Not enough hours in the day. Let me see what I can do in the next hour
Old Jun 2, 2008 | 11:48 AM
  #37
finagle69's Avatar
finagle69
Great, thanks Pete. As long as it's up by this weekend.
Old Jun 3, 2008 | 01:30 PM
  #38
Danny@BC's Avatar
Danny@BC
Hey guys, Pete is on his way back from Texas today but in the mean time he asked my to post up some pictures on here. From what it looks like in some of the customer pictures we have seen is that the rear spring seat was mounted upside down, this could be what is causing the rattling noise. Hopefully these pics will help out, he will be finishing up the write up as soon as he gets back and posting that up for you guys.
www.bcracing-na.com/g371.png
www.bcracing-na.com/g372.png
www.bcracing-na.com/g373.jpg
www.bcracing-na.com/g374.jpg
www.bcracing-na.com/g375.jpg
www.bcracing-na.com/g376.jpg
www.bcracing-na.com/g377.jpg
www.bcracing-na.com/g378.jpg
Old Jun 3, 2008 | 02:31 PM
  #39
finagle69's Avatar
finagle69
thanks for posting those up. i'm downloading them now for my install this friday!
Old Jun 3, 2008 | 02:32 PM
  #40
MaxToTheG37
so this is upside down right?
Old Jun 3, 2008 | 03:18 PM
  #41
IP37's Avatar
IP37
yep
Old Jun 3, 2008 | 03:21 PM
  #42
Danny@BC's Avatar
Danny@BC
no this is how it should look
  #43
MaxToTheG37
Are you sure??????? how can you adjust it?
Old Jun 3, 2008 | 03:22 PM
  #44
MaxToTheG37
wtf.....
Old Jun 3, 2008 | 03:27 PM
  #45
Danny@BC's Avatar
Danny@BC
by adjusting the spring perches under the spring with the spanner wrenches, also any adjustments you make to the spring you want to make adjustments to the shock as well
