BC Racing Coilovers
Old Mar 30, 2008 | 10:01 PM
  #106
symalik's Avatar
symalik
How will these handle the winter weathers in Chicago? Salt and all?
Old Mar 30, 2008 | 11:56 PM
  #107
Pete@BC's Avatar
Pete@BC
Originally Posted by IP37
aw that sucks
what are they made of? probably kind of like one of those flex shafts for a dremel aren't they? might look into making my own that are long enough
that or find another spot to run them
yeah, they are somewhat similar to those or like brake lines off a bicycle. I'll check to see if any longer sizes would be available.
Old Mar 30, 2008 | 11:58 PM
  #108
Pete@BC's Avatar
Pete@BC
We go the extra mile with our shock cartridges. We utilize 2 coatings to prevent rust. First is a nickle plating and 2nd is a chromium plating.
Old Mar 31, 2008 | 12:01 AM
  #109
808MIKE's Avatar
808MIKE
wow! Coilovers! I have an 07 Sedan, Will you guy's make one for our Sedans? Or just the G37's? Which would really suck if you make for only the Coupes!! Or will these fit the Sedans?
Old Apr 4, 2008 | 01:32 AM
  #110
Pete@BC's Avatar
Pete@BC
I haven't been able to verify on the new sedans. If we could get a local sedan to come in for a look and possible test fit, I'd be more than happy to check it out and get a write up on it. We are in the orlando, Fl. area if anyone is intrested.
I spoke with a bud of mine at infiniti, and he said the part #'s on the suspension is different, but that really doesn't say much. Even if just the valving is different than a coupe, that would change the part #'s.
Old Apr 8, 2008 | 02:54 PM
  #111
GregUMR's Avatar
GregUMR
So I'm a complete noob when it comes to coilovers. What are the main benefits/reasons to buying these? How do they adjust ride height ( as the 30 way adjustable is only for soft/hard stiffness right? ). Would I basically want these if I wanted less body roll and slightly lower ride height?
I heard someone mention this kit would prevent rolling on wheels. I've got two nice gouges in my front rims, not from me curbing it, but from me taking corners at the maximum velocity without losing control ( along with possibly some divots in the road ). Will these stop that or reduce it?
Also, will installing these coilovers effect the balance of the steering? I currently find the car VERY predictable in rear end break outs and find the car to have a fairly neutral steer. I definitely don't want to lose that.
Old Apr 11, 2008 | 09:37 AM
  #112
GregUMR's Avatar
GregUMR
Anyone?
Old Apr 11, 2008 | 09:44 AM
  #113
IP37's Avatar
IP37
Originally Posted by GregUMR
Anyone?
hurrr ya go..
https://www.myg37.com/forums/supporting-vendors/179142-what-everyones-been-waiting-for-bc-racing-coilovers.html
you'll have a better chance at getting answers in that thread. they've probably already been asked actually
Old Apr 15, 2008 | 03:26 AM
  #114
herrjr's Avatar
herrjr
I'm assuming that this set isn't monotube; will there be a monotube set in the future?
Old Apr 15, 2008 | 08:35 AM
  #115
IP37's Avatar
IP37
why assume when you can just read?
https://www.myg37.com/forums/showthread.php?t=179142
Originally Posted by Black Guy
30 Levels of Dampening Adjustability (Clicks)
Height is fully adjustable
Mono-Tube Design For Maximum Performance
Old Apr 15, 2008 | 12:38 PM
  #116
herrjr's Avatar
herrjr
LOL, thanks! I ran a search under "monotube," didn't think to check it with a hyphen.
Stevolkz33
May 28, 2016 02:36 AM
BurtoN86
Nov 3, 2015 04:40 PM
Kojack
Oct 9, 2015 05:53 PM
stm37s
The M - Spot
Oct 1, 2015 06:53 AM
