2012 g37x installing interior LED's and now none of them work!
Old Feb 24, 2020 | 05:34 PM
Dopery's Avatar
Dopery
Okay so a bit of backstory, i replaced the dome lights up front, and in the back seats with leds, as well as the front door lights at the bottom. When i did all of these everything was working fine. Flash forward a week and im going to try and install my vanity lights, the little fuse looking light bulbs in the visor, i pulled it out, tried popping in an led that was obviously too big (didnt force it just sized it up) realized it was too big and went to install the old one and now none of my interior lights work. exterior lights including brake lights are still working, sun roof is still working... Ive obviously been searching about this for a little bit now and have tried disconnecting the battery for a few minutes to see if that fixed it and it didn't. Also checked in the 3 fuse box locations and didn't notice any fuses popped. I only looked at the fuses that could have been related to lighting. Any suggestions?? Thanks.
Old Feb 24, 2020 | 06:08 PM
Dopery's Avatar
Dopery
I fixed this issue by replacing a 10amp fuse labeled as (room lamp) in the fuse box located by e brake. Didnt think to check that one first time through. Hope this can help someone else out sometime
Old May 20, 2020 | 08:25 PM
Cjfrancis571's Avatar
Cjfrancis571
interior lights don't work
I was swapping oh my LED lights on the trunk when I saw a little Spark now none of my interior lights will come on I have checked all my fuses room lamp fuse electric fuse even the fuse box under the hood and all the fuses are good can anybody help me out with what's the next thing I can do
Old May 20, 2020 | 08:28 PM
Dopery's Avatar
Dopery
There's a fuse box area next to the obd2 port or the hood release, there's a 10a fuse for the "room lamps" it was the culprit in my case. Replace it and should be good to go. Hope this helps. Pull out the room lamps one again and put a flashlight behind it. Mine didn't look too bad until I really inspected it. Good luck
Old May 20, 2020 | 09:18 PM
Cjfrancis571
lol I replaced it already still no change
milosz
General Tech Questions
Jul 28, 2025 10:53 PM
Keroro
Apr 16, 2013 08:22 AM
g37xsp
MODDING 411
Oct 6, 2011 04:01 AM
sunny051488
May 23, 2011 11:36 PM
jblyden20
12
Dec 14, 2010 10:45 AM
