I’m doing it! Black Headliner, Cracked Dash Solution and no more Vibrations
Old Dec 16, 2020 | 09:16 PM
  #256
sobeIPL's Avatar
sobeIPL
@Joyryde My fiancé’s parents live there and we alternate holidays. I was actually thinking of mailing the other visor and some supplies to her parents so I have something to do while I’m there, lol. I still don’t get why your killing the handles unless you just don’t like them now that I figured out how easy they are to pop in. If I were to fill them in, I’d probably use some epoxy style molding stuff. It’s cool, you take some play doe type stuff from can A, take some from can B, massage them together then fill the area and it’ll harden. It sands well too. Are you using any foam?
Old Dec 16, 2020 | 09:20 PM
  #257
Joyryde's Avatar
Joyryde
I'm not going for luxury style feel for the car like you are. I'm trying to make it more sporty, reason why I barely have any sound insulation left in the car. I don't like grab handles because the only people that use it are ones that are scared while driving and mother-in-laws. I will be using the expandable foam made by locite. I will sand it down so it will be smooth and flush with the headliner. Which part of Cali are you going to? Maybe I can give you a job to do
edit: I just read the last sentence. That looks so wrong
Old Dec 16, 2020 | 09:57 PM
  #258
sobeIPL's Avatar
sobeIPL
lol. I’ll be in the suburbs of Sacramento. I’m still in the tank on how to do the passenger visor. The driver side was much easier b/ the q60 is already a clam. I don’t see how you can use the G visor even if you delete mirror b/ the swing arm isn’t going to work painted. It’s going to chip. Just get a q60 visor and I’ll walk you through it. It’s not that hard (just a little time consuming).
Old Dec 16, 2020 | 10:52 PM
  #259
Joyryde's Avatar
Joyryde
Dang, that's far! Thing with the Q60 sun visors is that they have the airbag label (thanks to America being very sue-happy) I will try and talk to a shop 15 miles away from me to see if they can do it. I will still be deleting the mirrors so it will probably be easier. My swing arm that is painted has held up fine for 1 year and a half. It actually has not sign of peeling at all.
Old Dec 17, 2020 | 09:02 AM
  #260
sobeIPL's Avatar
sobeIPL
@Joyryde airbag sticker doesn’t matter. I’m suggesting you wrap over it.I’m mainly suggesting the q60 visors for the black parts but if your paint is holding up, probably not needed and you can use the G. Show me your visors so I can see where it went bad for you.
Old Dec 17, 2020 | 12:16 PM
  #261
rotarymike's Avatar
rotarymike
Moderator in Moderation
If you're going for sportier/lighter, why not visors from some base model Nissan like an Altima? I've seen those in black, and without all the doodads.
Old Dec 17, 2020 | 04:50 PM
  #262
sobeIPL's Avatar
sobeIPL
Altima visors should def help out with the track times.
Old Dec 17, 2020 | 04:57 PM
  #263
rotarymike's Avatar
rotarymike
I'm not actually joking - if you're changing things so drastically, why not look at other car's parts that are the color you want and maybe lighter? FX35 or Max etc?
Old Dec 17, 2020 | 06:32 PM
  #264
sobeIPL's Avatar
sobeIPL
When you do headliner the best visor is the easiest one to wrap, lol. The fitment is finicky too. I don’t think many visors would bolt up and fit properly. If they do, they are likely the same visor so it’s moot. I mean mine came out great. I’m trying to convince @Joyryde to man up and try wrapping his again.
Old Dec 17, 2020 | 09:13 PM
  #265
Joyryde's Avatar
Joyryde
These are how mine came out from last year. I hate sun visors so much. I’m going to see how much they charge. I’ll still be doing a vanity mirror delete again. And Mike, already tried that. Most of them are too light for my charcoal suede or come with crappy Nissan fabric and the Americanised airbag stickers. I actually like @sobeIPL ’s work on the leather sun visors. Reminds me of older BMWs.
Old Dec 17, 2020 | 09:52 PM
  #266
sobeIPL's Avatar
sobeIPL
@Joyryde Did you even open it? With the clam it’s easy b/ you just wrap material around to the inside and then close it. Perfect edges.
Old Dec 17, 2020 | 11:19 PM
  #267
Joyryde's Avatar
Joyryde
Yes. I used JB weld to seal the material inside. I couldn’t open it all the way though. Were you able to open it all the way?
Old Dec 18, 2020 | 12:44 PM
  #268
sobeIPL's Avatar
sobeIPL
@Joyryde You definitely need to crack it all the way open. The only tricky part is having to remove the slider b/ there is two screws under it you gotta get to. After that just pull and pry like hell. Once you have it open, you should be able to wrap it all easily and able to wrap around all the edges. Opening it up all the way will also let you remove the mirror so you can properly fill it in with whatever compound so it’s not lumpy. As far as adhesive, I have used weldwood classic for everything and it works amazingly. Not saying JB weld is bad, I’m not too familiar with it tho for fabric (I used it for metal before but that’s it).
Here is what the open G visor looks like inside.
Old Dec 18, 2020 | 01:09 PM
  #269
Joyryde's Avatar
Joyryde
@sobeIPL Man, you're good with this. I couldn't seem to open mine regularly and went through 2 sun visors I bought from ebay for pennies last time and chickened out with the other ones I had. What do you mean by slider B? Is it the little area that holds the bead-shaped plastic that latches onto the sun visor clips? This will probably help me a lot.
Old Dec 18, 2020 | 03:56 PM
  #270
sobeIPL's Avatar
sobeIPL
All it takes is no fear, lol. Full disclosure I forced it open and tore out the screws because I couldn’t figure it out either. I will have to finesse my passenger open tho because the q60 passenger is this cheap piece of **** styrofoam, not a clamshell like both G visors and driver side Q so I’ll need to use it.
So “Slider B” is just slider. The “B” was me short cutting writing because as “b/”. So there is no slider “A” either, lol. By slider I mean the only thing that slides, the thing that you can pull out to block the sun when it’s hitting the left side of your face.
So pull the slide out (about 90%) until you see this tab...
That tab is what stops the slide from coming all the way out. Push it down. Now here is the part I don’t get, there is another tab on the other side but there isn’t a hole to get at it. I think maybe just releasing the first tab should give you enough movement to jiggle it over the other tab. Here is what the tabs look like released...
now that you can take the slide out, you’ll see the screws that go here...
take out those screws and then the rest of it is just prying.
Note that I posted this a while ago and @BULL mentioned something as to how to get to the other tab but I didn’t quite get what he meant. Maybe he can expand. I just don't see anyway to push that tab but I think once you release the first you can jiggle the second like I said. I can’t test it b/ mine is all jacked up already. Worse comes to worse, just drill a little hole to get the second tab. The visor already looks like Swiss cheese so one more hole is whatever.
Here is what I’m dealing with.
Trying to scavenge the black parts from this ****ty Q passenger visor to Frankenstein to my passenger G visor. This foam is like carbon fiber foam. It’s tough as ****. Trying to get the parts out so I can bring them and the G visor and a piece of leather with me to Cali to keep me busy. The swing arm is stuck to that white piece and I have no clue how to get it free. I’m about to grab my hand saw...
