Notices
Help Leaking under passenger glove box in G37 Coupe
Old 12-15-2019, 10:52 PM
ABlake54
ABlake54's Avatar
I need help. Does anyone know how and why water keeps leaking on my passenger side floor when it rains heavy or even a car wash. It’s not the sun roof drain.
Old 12-15-2019, 11:57 PM
PNW_IPL
PNW_IPL's Avatar
Sunroof drains. Specific the firewall grommet. Very common. Not so common is the windshield leak. If you have not.personally cleaned the drains or replaced or resealed the firewall grommet it's that.
Whiterocket (01-15-2020)
Old 01-15-2020, 06:42 AM
Whiterocket
Whiterocket's Avatar
I had this issue. I changed the sunroof tubing to drain out of the condenser drain tube and resealed the firewall grommet. Havent had a problem since. If you do some searching in this forum there is a fix for just $15. That's the one I used and I've had no issues.
03Mach69Mach (01-31-2020)
Old 01-26-2020, 09:22 AM
PNW_IPL
PNW_IPL's Avatar
Just did mine. You have a lot more water than you know because the floor dips and there's 4 inches deep atleast and then foam there. Definitely pull the tube grommets.
I added a straw to help prevent future blockages.
Old 01-26-2020, 09:34 AM
Whiterocket
I did mine a while back but I didnt use the factory grommets. I rerouted the drain tube to the ac condenser drain tube. It now drains under the car. I also used a clear silicone around the main grommet where all the wires are under the hood and havent had one drop of water since. I actually found a thread on here where it shows all the steps. Cost me $15 in parts from Lowe's. New clear drain tube and 2-3 plastic fittings and a few zip ties.
Old 04-30-2024, 08:59 PM
JRogers
JRogers's Avatar
$15 fix
How do you search the forum for the $15 fix? Infiniti told me it was the door trim, cost a lot to replace and it stilk leaks.
Old 05-01-2024, 08:59 PM
beefychicken
beefychicken's Avatar
try searching for sunroof drain or sunroof drain leak or passenger or driver leak.
Here is one thread i found, i am sure there are others, just takes a minute and some reading to get to where you want.
https://www.myg37.com/forums/showthr...errerid=369648
Npg96
04-11-2019 02:48 PM
Huaniitoo
04-07-2018 01:53 AM
Blennin3000
12
03-27-2018 09:37 PM
Joshua Thomas
10-21-2017 11:01 AM
9whiteG
General Tech Questions
05-29-2014 03:53 AM
Quick Reply: Help Leaking under passenger glove box in G37 Coupe
