Seat Squeak
Old May 16, 2019 | 03:11 AM
Mojo_Dp's Avatar
Mojo_Dp
Seat Squeak
Both my Sedan seats squeak. My old one was a lot worse then my new one, but its still noticeable. I notice it when I take heavy turns or go over speed bumps. Would like to know if anyone else had this issue. I'm 6 foot 3 and around 200 pounds. I don't think im too heavy for the seats to handle my ***.
Old May 16, 2019 | 03:37 PM
Entcee's Avatar
Entcee
My divers seat squeaked! Seemed to be coming from the right side near the center console. Not sure if it was the side bolster, the hinge between the upper and lower half, or the seat bracket on the floor. I carefully used WD-40 in a few areas after it drove me nuts on the way home one day. It seemed better but was still there, then slowly went away. Not sure if the WD-40 worked it way into where the squeak was, or if the warmer weather fixed it. Will find out this winter!
I am 6 foot 2 and 200 pounds so this sounds like a conspiracy!
Old May 16, 2019 | 04:02 PM
Mojo_Dp's Avatar
Mojo_Dp
Originally Posted by Entcee
My divers seat squeaked! Seemed to be coming from between the right side near the center console. Not sure if it was the side bolster, the hinge between the upper and lower half, or the seat bracket on the floor. I carefully used WD-40 in a few areas after it drove me nuts on the way home one day. It seemed better but was still there, then slowly went away. Not sure if the WD-40 worked it way into where the squeak was, or if the warmer weather fixed it. Will find out this winter!
Lool thanks for the tip, I’ll try that. And yes it is a big conspiracy.
Old May 18, 2019 | 11:43 AM
codeflux's Avatar
codeflux
20 Year Member
aha same here! and i'm not even 180lb. the squeak seems to go away if i lean left a bit. wd-40 here i come. thanks guys!
BurtoN86
Dec 22, 2015 05:17 AM
TheLocNar
Jun 1, 2015 11:36 AM
i3eezenotch
Oct 14, 2013 12:43 PM
Tribute
Car Care & Detailing
Mar 29, 2010 01:27 PM
