Wipers not cleaning the same area?
Old Apr 24, 2019 | 06:20 PM
Psycho's Avatar
Psycho
So I decided to order some PIAA Si-Tech wiper blades since the ones of my car decided to chatter.. After installing the new wipers I noticed that they stop roughly an inch before the old ones would stop wiping.. I have a picture for reference.. is there anyway I can fix this or is it just how it’s gonna be now? Should I return those wipers? They are the exact same size as my old ones so I’m a little confused..
Old Apr 24, 2019 | 06:41 PM
qmantran's Avatar
qmantran
Has nothing to do with the wiper blades. It's your wiper arm that needs to be adjusted.
Old Apr 24, 2019 | 06:45 PM
Psycho's Avatar
Psycho
Any idea on how to do that?
Old Apr 24, 2019 | 06:49 PM
Selym's Avatar
Selym
Did you pull the wiper arm off its splines for some reason?
Old Apr 24, 2019 | 06:52 PM
Psycho's Avatar
Psycho
Nah man I just pulled off the old wipers and put these new ones I didn’t touch the arm at all.. I don’t see how the arms can be the problem if when I put the old wiper back on, it went back to cleaning the same area as before
Old Apr 24, 2019 | 08:04 PM
staskz's Avatar
staskz
yea take off the trim piece hiding the screw on the arm, unscrew it adjust it and screw it back in. simple.
Old May 4, 2019 | 05:53 PM
codeflux's Avatar
codeflux
20 Year Member
I had the same problem when I switched from OEM blades to Trico Flex blades (they last longer and clean better, in my testing).
Unscrew the bolt holding down the blade arm, pull off the arm, slightly shift it, and screw it back in. It may take a few tries to get it where you need them to be, but that's how you do it.
Old May 4, 2019 | 10:41 PM
Psycho's Avatar
Psycho
Thanks you guys I got it fixed !
Sir_Altitude
Jun 1, 2018 03:19 PM
MetalMan
Feb 27, 2015 07:40 PM
xevious10
Aug 17, 2010 02:22 PM
PeterUbers
Sep 20, 2009 11:01 PM
