Window will not open
Old Aug 31, 2018 | 11:56 AM
donscastle's Avatar
donscastle
Hello, 2008 G37 Coupe - the window on the passenger side will not open. The 'auto' drop when the door opens works - does this mean the motor is good? Neither door switch moves the window. Looking for diagnosis and fix, please.
Thank you, Don C.
Old Aug 31, 2018 | 04:19 PM
telcoman's Avatar
telcoman
Thank you, Don C.
FSM
http://www.nicoclub.com/FSM/G37/Sedan/2009/PWC.pdf
See page pwc-21
"Door glass moves UP/DOWN by receiving the signal power window main switch or front power window switch(passenger side).PASSENGER SIDE : Component Function CheckINFOID:00000000042406001.CHECK POWER WINDOW MOTOR (PASSENGER SIDE) OPERATIONCheck front power window motor (passenger side) operation with power window main switch or front powerwindow switch (passenger side).Is the inspection result normal?YES>> Power window motor (passenger side) is OK.NO>> Refer toPWC-21, "PASSENGER SIDE : Diagnosis Procedure".PASSENGER SIDE : Diagnosis ProcedureINFOID:00000000042406011.CHECK FRONT POWER WINDOW MOTOR INPUT SIGNAL1. Turn ignition switch OFF.2. Disconnect front power window motor (passenger side) connector.3. Turn ignition switch ON.4. Check voltage between front power window motor (passenger side) harness connector and ground."
Telcoman
Eddystone
Apr 12, 2015 11:56 PM
AuthorizedUser
Oct 22, 2013 01:30 PM
Techjunkie
Mar 12, 2011 01:42 PM
IMFROMNEWYORK
Aug 27, 2010 04:47 PM
blazeahundo2
May 25, 2009 04:03 PM
