2009 g37x windows issue
hey.
i just bought a 2009 infiniti g37x. love the car but im having an issues with the windows
only driver window goes down,the sunroof also works but the other 3 windows dont work, i tried each door individually and nothin
i also tried the master control on the driver door and nothing, the lock is not engaged
suggestins?
is this common?
suggestins?
is this common?
hey.
suggestins?
is this common?
suggestins?
is this common?
Follow the troubleshooting steps in the FSM
http://www.nicoclub.com/FSM/G37/Sedan/2009/PWC.pdf
Fuses, corrosion in the wiring harness?
Use your multimeter to troubleshoot
3.CHECK POWER WINDOW SERIAL LINK CIRCUIT1. Turn ignition switch OFF.2. Disconnect BCM connector.3. Check continuity between BCM connector and power window main switch connector.
Good luckIs the inspection result normal?YES>> Replace BCM. Refer toBCS-82, "Exploded View".NO>> Repair or replace harness.
Telcoman
looksezontv
Jun 5, 2019 05:13 PM
