T19 Torx bit fell in Steering Wheel
Old Dec 27, 2017 | 08:16 PM
grojas112's Avatar
grojas112
Hey guys. Earlier this morning I tried removing the steering wheel security bolts that hold the airbag. I noticed that the bolts were stripped. I dropped the t19 tied bit in the steering wheel. So now when I turn the wheel I hear the bit moving around.
Here comes the worse part. After trying to remove the bit by turning the wheel the horn started to honk. The only way I was able to disable the horn is by removing the negative cable from the battery.
Horn continues to honk when I connect the cable to the battery.
I have an appointment tomorrow with Infiniti but I wanted to know before the appointment if there is anything I can do to fix the issue since the car is out of warranty.
Thank you
Old Dec 27, 2017 | 09:51 PM
hurleyguys's Avatar
hurleyguys
can you snake a magnet in there to retrieve the bit? or attach a strong magnet to the shaft of a screwdriver and use that to fish it out.
not sure about the horn deal tho.
Old Dec 27, 2017 | 10:36 PM
Gio37's Avatar
Gio37
You might be using the incorrect size Torx bit.
When I removed my wheel ('08 G Coupe) I needed a T30 security Torx bit....this might be why you think the bolt is stripped using the incorrect size.
g/l
Old Dec 28, 2017 | 10:30 AM
qmantran's Avatar
qmantran
Are you sure T19 was the correct size for that bolt? That's a uncommon size... usually they are in increments of 5... T15. T20. T25, etc...
Techs love it when a customer brings their vehicles in for their own ****-ups.
Old Dec 28, 2017 | 10:56 AM
telcoman's Avatar
telcoman
The OP could perhaps roll the vehicle over on its roof.
Telcoman
Old Dec 28, 2017 | 11:01 AM
grojas112's Avatar
grojas112
I was able to get it out. Thanks
Old Dec 28, 2017 | 02:08 PM
Daddy Fat Sacs's Avatar
Daddy Fat Sacs
armature hour
muadib69
25
Jan 10, 2017 11:00 AM
Ryne
12
Dec 21, 2016 11:25 AM
rolltidealumni
Jun 7, 2016 10:43 AM
shaunjeremy
Jul 31, 2014 03:39 PM
Scarz
Sep 18, 2011 10:02 PM
