How much would it cost to fix this?
Old Sep 25, 2017 | 05:45 PM
Surfnazi's Avatar
Surfnazi
Do you not have full coverage if so just file a claim
Old Oct 4, 2017 | 09:35 PM
AARONHL's Avatar
AARONHL
if you are hoodrich enough you could just smear a tub of "bondo" over it, sand it down, and spray paint back
But I was at the infiniti dealership and saw new quarter panel they were about to put on a car. Yes they do sell it separately but it will be labor intensive prying off the damaged one and welding the new one on.
Old Oct 10, 2017 | 07:08 PM
Surfnazi's Avatar
Surfnazi
It has to be cut and welded in
Old Nov 7, 2017 | 06:22 PM
Waimin Louie's Avatar
Waimin Louie
update: got an estimate for repair, wheel, and alignment
Old Nov 7, 2017 | 10:22 PM
PNW_IPL's Avatar
PNW_IPL
thats very low. Id be terrified and get a second and third offer
Old Nov 8, 2017 | 05:14 AM
Surfnazi's Avatar
Surfnazi
That's low for the damage where it's located
Old Nov 8, 2017 | 09:58 AM
Exploded_Muffin's Avatar
Exploded_Muffin
I see parts quoted at $43.13 and I'm pretty sure a replacement quarter panel costs significantly more than that.
Are they gonna try to 'fix' and reuse your damaged quarter panel? If that's the case then take your car elsewhere
Old Nov 8, 2017 | 11:37 AM
Kris9884's Avatar
Kris9884
Lol that quote is with them pushing it all back out as much as they feel comfortable with and then filling the rest in with filler, yuck. I'd go somewhere else and request a quote using a replacement panel.
Old Nov 8, 2017 | 11:51 AM
Ryne's Avatar
Ryne
The Steering Wheel Guy
Getting a replacement quarter panel sounds like the "better" option, but you open up the car to a whole new world of corrosion opportunity doing that repair.
Old Nov 8, 2017 | 05:15 PM
Waimin Louie
Yeah that's what I'm assuming. Took my car to another shop, and said it would be around 4-5k by replacing the quarter panel
Waimin Louie
What would you suggest I do?
Old Nov 8, 2017 | 09:35 PM
Ryne's Avatar
Ryne
Take it to the most reputable shop in your area and let them do whatever they think is the best option. I would pick based on shop reputation, not based on what repair method they will use.
Old Nov 9, 2017 | 08:55 PM
soundkillr's Avatar
soundkillr
I would without hesitation, replace that 1/4. No amount of hammering or filler will ever make that right. Id give it two weeks before the filler/primer started to shrink and you would have bondo halos and filler/sand scratches all under the paint. 5k estimate is going to be the better repair. That lower estimate is a joke. Be prepared, ill bet the inner structure is damaged as well.....
the_wolff
Mar 6, 2016 07:21 AM
wetboy44
Apr 14, 2012 06:07 PM
g37brad
Dec 18, 2010 05:44 AM
aliiin
Sep 4, 2008 11:06 AM
langrock2003
Mar 8, 2008 10:39 AM
