Window Auto-up issue
Old Aug 26, 2017 | 09:42 PM
hammonds42's Avatar
hammonds42
Hey everyone, I have one window on my 2010 G37 that won't auto up with either the driver controls or the control on that door. I am not really sure where the issue is coming from. Anyone have any ideas where I can start? Thanks in advance.
Old Aug 26, 2017 | 10:02 PM
hammonds42's Avatar
hammonds42
Never mind, figured it out and can't figure out how to delete post.
Old Aug 26, 2017 | 11:15 PM
slartibartfast's Avatar
slartibartfast
What was your solution?
Old Aug 26, 2017 | 11:30 PM
iCrap's Avatar
iCrap
Probably just had to do the reset procedure. Hold the button down 5 seconds, then hold the up button for like 5 seconds.
Old Aug 26, 2017 | 11:33 PM
slartibartfast
I had a window pull the same crapola, reset wouldn't work. Dealer replaced the motor.
Old Sep 10, 2017 | 10:28 PM
zois's Avatar
zois
I guess this will happen every time you need to reset your computer by disconnecting the battery. This procedure works by dropping the window then holding it up 5 seconds after the window has closed. Repeat for all windows.
Old Sep 11, 2017 | 10:54 AM
r2dmax's Avatar
r2dmax
Yeah, I did that. It won't work on my passenger front window. The other 3 are fine though
Old Sep 11, 2017 | 08:24 PM
zois's Avatar
zois
I did all 4 of my windows. When I first purchased my car I was messing around and i was able to lower all the windows by inserting the key and turning it to the unlock position. Well when I turned in to the lock position all but one window went back up. I have yet to try that after I was able to get the auto-up feature to work on all my windows.
