Front Headlight moisture, inside
Old Jul 19, 2017 | 04:39 PM
BoodG's Avatar
BoodG
I have an 08 G37s, and when the shop that fixed my car after the carwash's track messed up the underside redid that side, the headlight doesn't seat down like it should, but caused a leak. Now I have moisture inside fogging it up. It looks HORRIBLE. Is there a way to clean the inside of the headlight, or is it a replacement. If it is the latter, does anyone know where to get good replacement headlights rather than EFFING Infiniti?
Old Jul 19, 2017 | 04:46 PM
Victory's Avatar
Victory
If it didn't occur before the repair, That sounds like a bodyshop problem. Clearly the headlight was removed for the repair and was not properly reinstalled. Take it back to them.
Old Jul 24, 2017 | 01:25 PM
Detail's Avatar
Detail
You can also try dropping a few silica packets behind the projector if its minimal fogging.
Old Jul 24, 2017 | 02:33 PM
NealP's Avatar
NealP
The hard part with getting them to fix it is proving it's their fault but it's worth a shot especially if it's not seated correctly. Short of getting them to repair/replace it you can bake them to open them up then seal it correctly yourself. Kind of a pain though. If you don't want to do that yourself and they shop won't help you then check for a used one online. Good luck
Old Jul 24, 2017 | 04:14 PM
Victory's Avatar
Victory
If the shop gives you trouble, complain to your insurance company
