Oil Maint. light on after only 2500m
Old May 5, 2017 | 01:36 PM
Datez's Avatar
Datez
Hi folks,
I have a 2008 G37S coupe. I got a full oil change almost exactly 2500 miles ago, and last night my oil maintenance light came on. I checked my oil, and it was on the Low portion of the dipstick. I have no leaks, I don't drive too aggressive, I usually drive around 80mph on mostly flat roads, and don't really travel longer than 30-40mile commutes max. As of the last two weeks as well, I have been using cruise control to save on gas.
Is this normal for this car to be burning that much oil?
If not, what could the issue be?
Old May 5, 2017 | 02:54 PM
micafd3s's Avatar
micafd3s
could be the dreaded rear timing gasket leak...
Old May 5, 2017 | 04:01 PM
Datez's Avatar
Datez
Wouldn't the leak be visible? I don't have any oil spots under my car. I also don't smell or see anything ender the hood.
Old May 5, 2017 | 04:29 PM
VOLK_TE37's Avatar
VOLK_TE37
Is this oil light on the center LCD? That is the maintenance reminder which can be programmed and reset. This has nothing to do with the engine having issues.
There is an oil pressure warning light which is not located on the LCD. That's what you would be more concern about.
Old May 5, 2017 | 05:40 PM
stealthee's Avatar
stealthee
If it's just the oil life monitor then it wasn't ready when the oil was changed.
People seem to think it knows when you change the oil. It doesn't and has to be manually reset.
Old May 5, 2017 | 05:51 PM
Datez's Avatar
Datez
How do I reset the oil light? But regardless, the oil went from full to low on the dip stick in 2500miles.
The light flashed on screen in the center of the cluster. Also, I looked at my exhaust tips this morning and they were pretty black. I think it is burning oil for sure, just don't know why. Using cruise control isn't harmful to the car in any way, is it?
Old May 6, 2017 | 02:38 AM
crookncastle's Avatar
crookncastle
which oil light are you referring to? oil maintenance or low oil level light? they are two different things. if you are having oil consumption issues you would need to do engine compression and engine leakdown tests. you might have bad or worn rings or cylinder sleeves.
