Dirty instrument cluster screen, help?
Old Mar 31, 2017 | 03:42 PM
DarienOG's Avatar
DarienOG
Hey guys, I bought a G37 recently and everything is in excellent condition, except my instrument cluster screen, which has white spots that I have tried to remove with a few products, but nothing... When I apply any wet product, the spots get dark and it looks better, but when it dries up it comes back. have any of you ever experienced anything like this? Any suggestions?
Old Mar 31, 2017 | 03:55 PM
PNW_IPL's Avatar
PNW_IPL
It happened my my old acura rl. What i think happens is the car sat for a long while and condensation built up and when it dried it left it spotty.
Or someone used a harsh cleaner.
You may have to replace that piece with a used unit.
Old Mar 31, 2017 | 04:04 PM
ILM-NC G37S's Avatar
ILM-NC G37S
Looks like someone sprayed something either to clean/polish/armor-all the interior and overshot it onto the cover. Same thing happened to me. It will not come clear. I ended up buying a new cluster cover and called it a day.
p/n: 24813-JK00A, Cover-Front, Combination Meter
$42.32 as of 3/31/2017 at parts.infinitiusa.com or $27.51 at discoutinfinitiparts.com
Old Mar 31, 2017 | 04:09 PM
Selym's Avatar
Selym
I wonder if a plastics polish will take this off. I'm thinking of something like NOVUS.
Old Mar 31, 2017 | 04:12 PM
DarienOG's Avatar
DarienOG
Thank you, this information really helps!
Old Mar 31, 2017 | 04:13 PM
PNW_IPL's Avatar
PNW_IPL
how hard was install?
Old Mar 31, 2017 | 04:15 PM
DarienOG's Avatar
DarienOG
I was gonna buy PlastX but wasn't sure if it was worth the try or if I should just replace it
Old Mar 31, 2017 | 04:26 PM
ILM-NC G37S
The whole project took me about one (1) hour. Removing the gauge cluster is tricky but doable. The front cover is retained to the cluster by a few plastic tabs. It literally pops right off.
Old Mar 31, 2017 | 04:52 PM
hurleyguys's Avatar
hurleyguys
On my old g35 i had water spots on my cluster also. I removed the cluster and used normal car polish and wax on it. the spots came out but took a while cause you have to do it by hand. mine only looked like water spots and not solid dots like yours.
if you have polish already it couldn't hurt to try before you spend the 40 dollars to get a new one.
Old Apr 1, 2017 | 05:25 AM
GeoNJ77's Avatar
GeoNJ77
I had the same issue when I bought mine, the cluster was smudged, and there were spots that the dealer tried to clean, and were slightly scratched. My fix (seriously), I took a paper towel and put a little bit of olive oil, then cleaned the cluster with it. Not enough to drip, but just enough to lubricate. I had the car for almost a year, and the cluster looks clean, you can see some spots faint, but definitely much better. Worth a try, and will save you$$
Old Apr 1, 2017 | 05:06 PM
HoldmyMouse's Avatar
HoldmyMouse
Care to elaborate a bit more on how to remove the cluster? Maybe some pictures would be nice.
Old Apr 1, 2017 | 11:36 PM
DarienOG's Avatar
DarienOG
*fixed*
Originally Posted by GeoNJ77
I had the same issue when I bought mine, the cluster was smudged, and there were spots that the dealer tried to clean, and were slightly scratched. My fix (seriously), I took a paper towel and put a little bit of olive oil, then cleaned the cluster with it. Not enough to drip, but just enough to lubricate. I had the car for almost a year, and dthe cluster looks clean, you can see some spots faint, but definitely much better. Worth a try, and will save you$$
I was a little skeptical about this, but I tried it and it got rid of most of it, if not all! Thank you bro!
Old Apr 2, 2017 | 01:04 AM
Lucasmdemele's Avatar
Lucasmdemele
I never
imagined or thought about putting oil on there and had tried almost everything to get rid of the stupid spots on my cluster this really worked! Thank you all!!!!
Old Apr 3, 2017 | 05:24 AM
Surfnazi's Avatar
Surfnazi
Olive oil will spoil plastic polish works just fine
Old Apr 3, 2017 | 06:09 AM
DarienOG's Avatar
DarienOG
yes... I just tried olive oil cause i already had some and it was worth the try you know...
