I am sure if you remove the radiator cover, you will be able to figure out what needs to be done. I don't own a coupe and never really took my grill out yet but seems like an easy job
hardest part is the cover. mine ended up with a small crack. i just glued it filled it and sprayed it black. might as well cut out the holes holding the 2 pins too. those are bitches to unhook
