Headlight/foglights
Old Aug 7, 2016 | 12:17 AM
khan_g37x_'s Avatar
khan_g37x_
Headlight/foglights
What's up guys I see a lot a g Sedan owners that have fog lights without running headlights any suggestions on how it's done ??
Old Aug 7, 2016 | 11:53 AM
ETrev's Avatar
ETrev
You're talking about the fog lights running independently?
There's a module for that.
Here's a link: KP Technologies
Old Aug 8, 2016 | 12:28 PM
Dang's Avatar
Dang
Having the KP Technology module I would advise against it. It doesn't work 100% the way you'd expect. Common issue I've read and one I experience is when the fogs are off, and I use my left blinker the fogs will turn on. To remedy this, my fogs are always on and I use them as DRLs. Another issue I have is there is zero support for the product. I've posted on their forum without a response.
Old Aug 8, 2016 | 01:20 PM
TBau651's Avatar
TBau651
Tap an "always on" fuse in the cabin, run that to a toggle switch so you can still turn them off, then send that power wire through the fire wall down to the fogs, ground your negatives and problem solved.. This DYI I made goes a little beyond what you are trying to accomplish but might give you some ideas:
https://www.myg37.com/forums/d-i-y-i...-modified.html
Old Aug 10, 2016 | 05:40 PM
saywat?'s Avatar
saywat?
dont buy that kp tech crap. u can buy fog light harness kits on ebay and connect it straight to ur parking lights or on a switch. you dont even need to run the wires to the fogs u can just tap it at the ipmd box by the batter for a clean install
Old Aug 11, 2016 | 03:57 PM
khan_g37x_'s Avatar
khan_g37x_
Thanks guys I appreciate it I didn't hear such positive for kp tech so I'm gonna steer clear I will update once I figure this out
indycoupe
Feb 23, 2017 12:50 PM
Apr 19, 2016 05:01 PM
JBurch175
Apr 17, 2016 02:52 PM
Ryne
Mar 21, 2016 07:48 PM
