Passenger Side View Mirror Broken after Window Repalcement
Hey guys!
A couple of weeks ago my car was broken into from the passenger side and the window was smashed... I recently just got a window replacement, and all of a sudden I can't move my right side view mirror as in change the placement view with the ****. However, the left one works just fine.
Is it possible when they replaced my passenger window, it could have been messed with? Just wondering... and if I call them they'll just ask me to come in today, but I can't since I'm working, and they'll be closed by the time I get off work. Just trying to figure this out because this will be my 3rd time going in for the same window, and it's quite annoying.
Thank guys!
Oh, its an '08 g37 coupe if this info is needed.
Thank guys!
I will bet anything the guys who replaced the window forgot to plug the wiring harness back in for the side view mirror. Unfortunately, the door panel will need to taken off again but should be a simple fix. Good luck.
UCLAg37
UCLAg37
Sounds like a disconnected harness imo as well. Best of luck with the situation and keep us posted when you get it fixed! Take it back to whoever installed the mirror. I'm assuming they wont double charge you if it is indeed the harness since it was their fault.
