Projector shroud removal
Old Jul 2, 2016 | 03:00 PM
ShuuraRG's Avatar
ShuuraRG
in light of not being able to capitalize on Alen's headlight deal, I've decided to mod my own heads with parts I'd purchased months back. I've opened the heads, easy enough, but am a bit stuck with the shrouds. I can't seem to figure out how they're to be removed. I see two screws that require a long philips head, but one is completely inaccessible from the rear of the headlight. I figure that there must be another way. Any ideas/help?
Old Jul 2, 2016 | 03:11 PM
ShuuraRG's Avatar
ShuuraRG
I've found my answer here - https://www.myg37.com/forums/g37-sed...n-led-diy.html
Old Jul 2, 2016 | 03:36 PM
Daddy Fat Sacs's Avatar
Daddy Fat Sacs
Or this one
https://www.myg37.com/forums/d-i-y-i...s-install.html
nice looking stuff...Panamera shrouds?
Old Jul 2, 2016 | 04:05 PM
ShuuraRG's Avatar
ShuuraRG
Or this one
thanks!
yes sir! Only, the Panamera's were broken on arrival and I just didn't care enough to return them...
Old Jul 2, 2016 | 04:54 PM
ShuuraRG's Avatar
ShuuraRG
matt black with matt clear
Old Jul 2, 2016 | 05:17 PM
This is going to looks amazing when it's all done! I can't wait to see the final result! Nothing but props for going at this mod yourself!
Old Jul 2, 2016 | 05:33 PM
ShuuraRG's Avatar
ShuuraRG
thanks kenny! I'm letting the paint dry overnight and then putting things back together! I'd been putting this mod off for months and after not being able to swap with Alen, I'd decided that it was time to do it myself.
Old Jul 2, 2016 | 11:07 PM
Nice looking combo you're putting together. If possible try to mount you lights prior to reinstalling the covers so you can fine tune your cutoff w/ those spacers, it will be time well spent. It's going to look killer, I can already tell
Old Jul 3, 2016 | 12:52 AM
takeapieandrun's Avatar
takeapieandrun
I couldn't get the L-shaped phillips to work, it was just too tight after 8 years on my 07. I drilled a small hole in the back of the headlight plastic, and filled it tightly with all-weather sealant after.
Old Jul 3, 2016 | 01:05 AM
ShuuraRG's Avatar
ShuuraRG
thanks for the notice Brad!
I wish I'd have thought of that before closing them up.
I'll check and see how bad it is tomorrow. The only problem I have now is that the body shop that repaired my bumper and replaced my passenger headlight two years back used the wrong screws. I had a heck of a time putting the bumper back on. They'd also failed to include two of the 4 screws that mount the headlights to the body.
towerworld
Jul 15, 2016 04:26 PM
McStealth
May 3, 2016 07:58 AM
H03AssAss1n
Apr 30, 2016 01:47 PM
